512K E2Prom
Hello Stamp Programmers:
I need information on how to expand E2Prom on the BS2E.
I am looking for information on how to use 2 or more E2Prom in the Same
program without running other slots on the BS2E.
Using the I2c Buss I would like to switch to No. 2 E2Prom when the first
fills up in memory. I have used different addressing
on each EEprom . Also scaled logic to switch to the second EEprom when
the first filled up it's memory.
Used pull up resistors on each EEprom. I have been unable to get this to
work properly. The only way I can utilize the second
EEprom is switch to slot 1 on the BS2E using the same program in slot 1.
In other words what I am trying to do is make 2
512K EEproms look like 1-Meg memory configuration. I would appreciate
any help you can give me.
Sincerely.
Harry.
Sincerely.
Harry.
writes:
You can use several EEPROMs just by changing the CS pin.
You can not run I2C on a BS2E without a lot of additional programming. The
BS2E does not support the I2C command - only the BS2P family does.
Take a look the EEPROM on our site.
Sid Weaver
We're always thinking.....
http://www.visualmuses.com/chipcircuit/index.html
can't add it for additional CODE storage.
The PBasic runtime is really designed for a
2K eeprom. They've expanded it with the
multiple-bank technology -- but it's hard
coded in the Parallax proprietary PIC
code.
Having said that, you CAN use an external
I2C EEPROM with the BS2P for DATA storage
-- which is what it sounds like what you
want to do anyway.
Same
first
when
this to
slot 1.
appreciate
> Sincerely.
> Harry.
> In a message dated 4/19/2004 5:53:37 PM Eastern Daylight Time,
HR518@J...
> writes:
the Same
Here is the big clue.
Since the I2C can address any chip on the line with a unique address,
all you need to do is to change the address for the 2 (or more)
EEPROMs and re-set you data storage addresses in software to start at
the beginning of the second chip.
Dave
> Sid Weaver
wrote:
> While you can add EEPROM for DATA storage, you
> code.
> want to do anyway.
I think I missed something....
The origional poster said BS2E chip.
I didn't think the BS2E can use I2c.
The BS2P can and may be the chip needed to get this project done they
way he wants.
Comments ?
the
> Same
the
> first
> when
> this to
> slot 1.
> appreciate
> > Sincerely.
> > Harry.
to use your own sub to bit-bang. There are a few examples kicking around out
there somewhere. I did it on my BS2.
> From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6YXk1s83bi0Hf1_hb1b2wGQ7_0K9xqDotIwvJBBD06qzPeWXxp_Irp39jq03P5C6JNp-dJJNNJF2jg6FfA]davemucha@j...[/url
> Sent: April 20, 2004 9:17 AM
> Subject: [noparse][[/noparse]basicstamps] Re: 512K E2Prom
> way he wants.
> Comments ?
