DC Motor Direction Control
I'm building an indoor flying blimp for a class (actually, I'm hacking the
Tri-Turbofan
indoor flying blimp). I want to bypass the remote control and use other sensors
to control
the blimp's fan units. The fans are DC motors that spin both clockwise and
counterclockwise.
Can anyone direct me to a simple solution to build my own circuit that will
allow me to
control the polarity to the motor. I'm a newbie so simplicity is key. My
understanding is
that a relay may be the best bet, or perhaps an h-bridge. I just don't know how
to set
these up. I don't know any specifics about the motors that spin the fans other
than they
are small and light weight, about 3/4 of an inch long and about the diameter of
a AA
battery. The whole fan unit (which houses the RC receiver) runs on a 3V battery
(the one
that looks like a short AA battery).
Any advice? Thanks in advance.
~Haven
Tri-Turbofan
to control
counterclockwise.
allow me to
understanding is
to set
than they
a AA
(the one
~Haven
A simple h bridge would be the best if you just want to switch
motor directions there is a good write up. In nuts and volts in article
23 located at
http://www.parallax.com/html_pages/downloads/nvcolumns/Nuts_Volts_Downlo
ad_V1.asp
If you need to vary the speed then you might want to try the
Micro Dual Serial Motor Controller at
http://www.parallax.com/detail.asp?product_id=30052
Stephen Swanson
Technical Support Manager
599 Menlo Drive, #100
Rocklin, CA 95765
Phone (916) 624-8333
E-mail ..... sswanson@p...
Main site...... www.parallax.com
Educational site.... www.parallax.com/sic
Javelin Stamp... www.parallax.com/javelin
From: Haven [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ssmk6EDOtU6inP_ntgN7sD-CC86yFI5oq11aZwYwkwHgGXJCvSSlV1WrcH2IDQafCEYj4ax0UvYf_tyaOtU]birdahonk@y...[/url
Sent: Friday, April 16, 2004 4:46 PM
Subject: [noparse][[/noparse]basicstamps] DC Motor Direction Control
the Tri-Turbofan
sensors to control
and
counterclockwise.
will allow me to
understanding is
know how to set
other than they
diameter of a AA
battery (the one
~Haven
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
project but, just haven't justified it yet. Hopefully, I can justify
it soon.
Currently, I am just using a SPST and a SPDT relay. On/off and
forward/reverse respectively. Bought them at Radio Shack. I have a
schematic. E-mail me at FrankSmith512@y... if you want it. Let
me know if you have CAD software.
Best wishes,
Frank
--- In basicstamps@yahoogroups.com, "Stephen Swanson" <sswanson@p...>
wrote:
> Hello,
article
> 23 located at
lo
> ad_V1.asp
> Stephen Swanson
> Parallax, Inc.
> Rocklin, CA 95765
> From: Haven [noparse][[/noparse]mailto:birdahonk@y...]
hacking
> the Tri-Turbofan
other
> sensors to control
clockwise
> and
> counterclockwise.
that
> will allow me to
key. My
> understanding is
don't
> know how to set
fans
> other than they
> diameter of a AA
a 3V
> battery (the one
> ~Haven
Subject
> Yahoo! Groups Links
> abuse@p...
> Tri-Turbofan indoor flying blimp). I want to bypass the remote control and
> use other sensors to control the blimp's fan units. The fans are DC motors
> that spin both clockwise and counterclockwise.
> allow me to control the polarity to the motor. I'm a newbie so simplicity is
> key. My understanding is that a relay may be the best bet, or perhaps an
> h-bridge. I just don't know how to set these up. I don't know any specifics
> about the motors that spin the fans other than they are small and light
> weight, about 3/4 of an inch long and about the diameter of a AA battery.
> The whole fan unit (which houses the RC receiver) runs on a 3V battery (the
> one that looks like a short AA battery).
Your #1 concern will most likely be weight. Because of this I'd choose one
of the smaller H-Bridges since it should weight less than most DPDT relays.
There's a good tutorial at: <http://www.dprg.org/tutorials/1998-04a/>
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
To keep the weight down and because it sounds like the
motors don't pull too much current when they are
running, I would use the L293D. This 16-pin DIP chip
is two H-bridges on a chip with diode protection and
is very reasonably priced. I can't recall where I
bought mine but they were less than $5 a piece. And
best of all, they are very easy to hook up and the
Basic Stamp programming is very straightforward.
Hope this helps and good luck with the project. Take
lots of pictures and share what you have done with the
rest of us.
Take care and have a great day!!
James E. Merritt
__________________________________
Do you Yahoo!?
Yahoo! Photos: High-quality 4x6 digital prints for 25¢
http://photos.yahoo.com/ph/print_splash
Would you please post a schematic of how you hooked up the L293D?
On another board they kept insisting that I should use an H-bridge
but no one ever got around to posting a schematic.
I searched the net and found lots of variations which just made it
more confusing. I am controlling 3.5 amps. It is DC.
Frank
--- In basicstamps@yahoogroups.com, James Merritt <jamesem_99@y...>
wrote:
> Hi,
> rest of us.
> James E. Merritt
> Do you Yahoo!?
Here are a couple of links for the L293D that will be
very helpful. One thing, though, is that the L293D
can only handle 600 ma with a big heat sink. You said
that you are controlling 3.5 amps so in this case the
L293D won't work. There is, I believe, a larger
version of this chip, the L298 which can handle up to
4 amps with appropriate heat sinking. With that in
mind, here are the links:
www.me.metu.edu.tr/me407/documents/basic_stamp_II.ppt
www.me.umn.edu/courses/me2011/robot/technotes/L293/L293.html
This link os to Digi-Key for teh L298:
rocky.digikey.com/WebLib/ST%20Micro/Web%20Data/L298.pdf
homepage.ntlworld.com/seanellis/avrrobot_hw.htm
These should get you started.
Have a great day!!
James E. Merritt
--- franksmith512 <franksmith512@y...> wrote:
> James or someone else,
> up the L293D?
> use an H-bridge
> which just made it
> DC.
> Thanks,
> Frank
Do you Yahoo!?
Frank
wrote:
> Hi Frank,
> Have a great day!!
> James E. Merritt
> > up the L293D?
> > use an H-bridge
> > which just made it
> > DC.
> > Thanks,
> > Frank
> Do you Yahoo!?
a stamp.
jim
http://www.geocities.com/jimforkin2003/
From: Haven [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=m37uijkZbapx4VQ854OVRYRql3sdzuZSu9NC3X565qdmmkpk69ABNsiTHCB3R1Pp6usJg1_jgq9tj-3MjU8]birdahonk@y...[/url
Sent: Friday, April 16, 2004 7:46 PM
Tri-Turbofan
sensors to control
counterclockwise.
allow me to
understanding is
how to set
other than they
of a AA
battery (the one
~Haven
Yahoo! Groups Links
jim
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uohYMz0kbpZJ-n4UsHSGOM8R7ZQIlqPH1-Ny3qu2146e55oVOx-gIx8ASf6WEqWgJy4AUD_zyt_BWJHCwVWj_g]franksmith512@y...[/url
Sent: Saturday, April 17, 2004 10:27 PM
Subject: [noparse][[/noparse]basicstamps] Re: DC Motor Direction Control
Frank
wrote:
> Hi,
> rest of us.
> James E. Merritt
> Do you Yahoo!?
Yahoo! Groups Links
