capturing variable
I'm trying to communicate with an asynchronous device via SERIN and
SEROUT. It's communicating, but returns an unexpected result.
instead of giving me the expected 8byte ASCII hexadecimal string, I
get $7C. any idea why?
thanks for the help. Steve
_________________________________________________________________
'{$STAMP BS2p}
' declare variable
result VAR Byte
SendData:
SEROUT 9,16624,[noparse][[/noparse]82] 'sending ASCII "S" at 9600,N,8,1
ReadData:
SERIN 10,16624,2000, No_Data, [noparse][[/noparse]result] 'read the input on pin 10,
'store in variable "result"
DEBUG CLS, HEX? result 'convert to HEX and display...
'result = $7C
'should be 7F0000000836A410<CR>
STOP
No_Data:
DEBUG CLS, "Timed out"
'{$STAMP BS2p}
' declare variable
result VAR Byte
SendData:
ReadData:
'result = $7C
STOP
No_Data:
instruction....
Since the BASIC Stamp stores everything as a number anyway, prevent
possible errors when sending ASCII characters by simply embedding that
character. Like this:
SendData:
SEROUT 9, 16624, [noparse][[/noparse]"S"]
And, according to my BASIC Stamp, the ASCII code for "S" is 83, not 82.
-- Jon Williams
-- Dallas Office
From: stenote [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0oTcilLJqqpdY2E9w7DwywJq7I8CL0YyFyi1iqwgX1EURKyvMgSYRSFeV3QbG5nreC-2pmf_APIubFUNuHY]stepnote@c...[/url
Sent: Friday, April 16, 2004 2:05 PM
Subject: [noparse][[/noparse]basicstamps] capturing variable
'{$STAMP BS2p}
' declare variable
result VAR Byte
SendData:
ReadData:
'result = $7C
'should be 7F0000000836A410<CR> STOP
No_Data:
____________________________________________________________________
result VAR Byte
'1 loop through SEROUT/SERIN
SendData:
SEROUT 9,16624,[noparse][[/noparse]"S"] 'sending ASCII "S" at 9600,N,8,1
ReadData:
DEBUG CLS, HEX? result 'convert to HEX and display...result =
$E5 should be 7F0000000836A410<CR>
STOP
No_Data:
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Perhaps you're sending it an unexpected or incorrectly formatted
> instruction....
that
> SendData:
not 82.
> -- Jon Williams
> -- Dallas Office
> From: stenote [noparse][[/noparse]mailto:stepnote@c...]
and
I
> '{$STAMP BS2p}
> ' declare variable
> result VAR Byte
> SendData:
> ReadData:
10,
> 'store in
variable "result"
> 'result = $7C
> No_Data:
If I'm correct you are trying to receive 8 bytes. In that case
try the following. This code will bring in the 8 bytes. If you have any
questions please reply.
'{$STAMP BS2p}
'{$PBASIC 2.0}
result VAR Byte(8) 'setups an 8 byte array
temp VAR Nib ' used to access array for displaying
SendData:
ReadData:
SERIN 16,16624,2000, No_Data, [noparse][[/noparse]STR result\8] 'read the input of 8
bytes STORE in variable "result"
FOR temp = 0 TO 7
DEBUG HEX result(temp),CR 'convert to HEX and display...result = $E5
NEXT
STOP
No_Data: DEBUG CLS, "Timed out"
Stephen Swanson
Technical Support Manager
599 Menlo Drive, #100
Rocklin, CA 95765
Phone (916) 624-8333
E-mail ..... sswanson@p...
Main site...... www.parallax.com
Educational site.... www.parallax.com/sic
Javelin Stamp... www.parallax.com/javelin
From: stenote [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rxOxsd-rH7pIxNYIl9B7iLzEs4rMFR95k7ckpVrg-R874EuNdZIkdtE1meJcsE5170AFemGAmR8-iA]stepnote@c...[/url
Sent: Friday, April 16, 2004 2:15 PM
Subject: [noparse][[/noparse]basicstamps] Re: capturing variable
Jon: I tried that (see below). it still returns "$7C". thanks
result VAR Byte
SendData:
ReadData:
STOP
No_Data:
> instruction....
that
> SendData:
not 82.
> -- Jon Williams
> -- Dallas Office
and
I
> '{$STAMP BS2p}
> ' declare variable
> result VAR Byte
> SendData:
> ReadData:
10,
> 'store in
variable "result"
> 'result = $7C
> No_Data:
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
array, then use the STR modifier to capture it. Like this:
result VAR Byte(8)
idx VAR Nib
Then modify your receive code like this:
Read_Data:
SERIN 10, 16624, 2000, No_Data, [noparse][[/noparse]STR result\8]
DEBUG CLS
FOR idx = 0 TO 7
DEBUG HEX2 result(idx)
NEXT
STOP
-- Jon Williams
-- Dallas Office
From: stenote [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=39xMijJWqshFGy0x9xi6FYsrkVq_fWKC_TFl3udkuaSSyQHTi8ki6lJQjA7KUuDiL581pgyCqC3gR5dzyQU]stepnote@c...[/url
Sent: Friday, April 16, 2004 4:15 PM
result VAR Byte
SendData:
ReadData:
STOP
No_Data:
> instruction....
that
> SendData:
not 82.
> -- Jon Williams
> -- Dallas Office
and
I
> '{$STAMP BS2p}
> ' declare variable
> result VAR Byte
> SendData:
> ReadData:
10,
> 'store in
variable "result"
> 'result = $7C
> No_Data:
Yahoo! Groups Links
abuse@p....
first byte, makes sense. Here's what I tried, but now it "times out"
thanks, Steve
'{$STAMP BS2p}
' declare variable
result VAR Byte(8)
idx VAR Nib
'loop through SEROUT/SERIN
SendData:
ReadData:
SERIN 10, 16624, 1000, No_Data, [noparse][[/noparse]STR result\8]
FOR idx = 0 TO 7
NEXT
STOP
No_Data:
wrote:
> Aha ... you're only capturing the first byte. Create an eight-byte
> result VAR Byte(8)
> idx VAR Nib
> Read_Data:
> DEBUG CLS
> FOR idx = 0 TO 7
> NEXT
> STOP
> -- Jon Williams
> -- Dallas Office
> result VAR Byte
> SendData:
> ReadData:
10,
> STOP
> No_Data:
<jwilliams@p...>
> > instruction....
prevent
> that
> > SendData:
> not 82.
> > -- Jon Williams
> > -- Dallas Office
> and
string,
> I
> > '{$STAMP BS2p}
> > ' declare variable
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > 'store in
> variable "result"
> > 'result = $7C
> > No_Data:
Subject
> Yahoo! Groups Links
> abuse@p...
essentially the same thing, and I tried it and responded to Jon's
message. Now it "times out". a bit baffling at this point, but I
really appreciate the input from you guys.
thanks a lot. Steve
--- In basicstamps@yahoogroups.com, "Stephen Swanson"
<sswanson@p...> wrote:
> Hello stenote,
case
have any
> '{$STAMP BS2p}
> '{$PBASIC 2.0}
> SendData:
> ReadData:
8
> FOR temp = 0 TO 7
= $E5
> NEXT
> STOP
> Stephen Swanson
> Parallax, Inc.
> Rocklin, CA 95765
> result VAR Byte
> SendData:
> ReadData:
10,
> STOP
> No_Data:
<jwilliams@p...>
> > instruction....
prevent
embedding
> that
> > SendData:
> not 82.
> > -- Jon Williams
> > -- Dallas Office
> and
string,
> I
> > '{$STAMP BS2p}
> > ' declare variable
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > 'store in
> variable "result"
> > 'result = $7C
> > No_Data:
Subject
> Yahoo! Groups Links
> abuse@p...
Stephen Swanson
Rocklin, CA 95765
From: stenote [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=s9mbG-yGtSz8uCTzAkvl-EOjiIyUsDKkvvuf44vNVgEVG1sf-lloB2QkssPb9TCQC84odTeVBDU8M5xFrA]stepnote@c...[/url
Sent: Friday, April 16, 2004 4:13 PM
Stephen: thanks...I think between what you and Jon said is
thanks a lot. Steve
> Hello stenote,
case
have any
> '{$STAMP BS2p}
> '{$PBASIC 2.0}
> SendData:
> ReadData:
8
> FOR temp = 0 TO 7
= $E5
> NEXT
> STOP
> Stephen Swanson
> Parallax, Inc.
> Rocklin, CA 95765
> result VAR Byte
> SendData:
> ReadData:
10,
> STOP
> No_Data:
<jwilliams@p...>
> > instruction....
prevent
embedding
> that
> > SendData:
> not 82.
> > -- Jon Williams
> > -- Dallas Office
> and
string,
> I
> > '{$STAMP BS2p}
> > ' declare variable
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > 'store in
> variable "result"
> > 'result = $7C
> > No_Data:
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
is the baud setup "16624" equivalent to "9600,N,8,1"??
thanks
> Sure anytime.
> Stephen Swanson
> Parallax, Inc.
> Rocklin, CA 95765
> thanks a lot. Steve
> > Hello stenote,
> case
> have any
> > '{$STAMP BS2p}
> > '{$PBASIC 2.0}
> > SendData:
> > ReadData:
of
> 8
> > FOR temp = 0 TO 7
display...result
> = $E5
> > NEXT
> > STOP
> > Stephen Swanson
> > Parallax, Inc.
> > Rocklin, CA 95765
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > STOP
> > No_Data:
> <jwilliams@p...>
formatted
> > > instruction....
> prevent
> embedding
> > that
> > > SendData:
83,
> > not 82.
> > > -- Jon Williams
> > > -- Dallas Office
SERIN
> > and
result.
> string,
> > I
> > > '{$STAMP BS2p}
> > > ' declare variable
> > > result VAR Byte
> > > SendData:
> > > ReadData:
pin
> > 10,
> > > 'store in
> > variable "result"
> > > 'result = $7C
STOP
> > > No_Data:
> Subject
> > Yahoo! Groups Links
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
For inverted, true would be 240
Stephen Swanson
Rocklin, CA 95765
From: stenote [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=15yW7zLc2Gnute3Vk-2-QpKREq7pemIxQsgE4kX5ylD0CXfgAewG9RZYuNL70EC9D7cETTYtAgwbHgw]stepnote@c...[/url
Sent: Friday, April 16, 2004 4:33 PM
to confirm:
thanks
> Sure anytime.
> Stephen Swanson
> Parallax, Inc.
> Rocklin, CA 95765
> thanks a lot. Steve
> > Hello stenote,
> case
> have any
> > '{$STAMP BS2p}
> > '{$PBASIC 2.0}
> > SendData:
> > ReadData:
of
> 8
> > FOR temp = 0 TO 7
display...result
> = $E5
> > NEXT
> > STOP
> > Stephen Swanson
> > Parallax, Inc.
> > Rocklin, CA 95765
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > STOP
> > No_Data:
> <jwilliams@p...>
formatted
> > > instruction....
> prevent
> embedding
> > that
> > > SendData:
83,
> > not 82.
> > > -- Jon Williams
> > > -- Dallas Office
SERIN
> > and
result.
> string,
> > I
> > > '{$STAMP BS2p}
> > > ' declare variable
> > > result VAR Byte
> > > SendData:
> > > ReadData:
pin
> > 10,
> > > 'store in
> > variable "result"
> > > 'result = $7C
STOP
> > > No_Data:
> Subject
> > Yahoo! Groups Links
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
to check for the correct baud parameter (I see that Stephen has
addressed that) and what the actual output from your mystery device is.
-- Jon Williams
-- Dallas Office
From: stenote [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sk9EOAXIjB--PLTAvYSAJsFkMFysFs4jlsSdCTLXedK5Hd48Tkl-HaE3B1TuErAj9e5mxjhLUOCZmjl-]stepnote@c...[/url
Sent: Friday, April 16, 2004 6:08 PM
Jon: looks like it should work, I understand about capturing the
thanks, Steve
'{$STAMP BS2p}
' declare variable
result VAR Byte(8)
idx VAR Nib
SendData:
ReadData:
FOR idx = 0 TO 7
NEXT
STOP
No_Data:
> result VAR Byte(8)
> idx VAR Nib
> Read_Data:
> DEBUG CLS
> FOR idx = 0 TO 7
> NEXT
> STOP
> -- Jon Williams
> -- Dallas Office
> result VAR Byte
> SendData:
> ReadData:
10,
> STOP
> No_Data:
<jwilliams@p...>
> > instruction....
prevent
> that
> > SendData:
> not 82.
> > -- Jon Williams
> > -- Dallas Office
> and
string,
> I
> > '{$STAMP BS2p}
> > ' declare variable
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > 'store in
> variable "result"
> > 'result = $7C
> > No_Data:
Subject
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
way is up. the device was referred to in "stamp 2' page 46,
and 'was' the Point Six, Inc HA7S 1-wire interface, which apparently
now belongs to "Embedded Data Systems."
thanks for all the help, guys, I may be back at you in a day or two.
Steve
wrote:
> Well, there's nothing wrong with your BASIC Stamp code -- you may
need
device is.
> -- Jon Williams
> -- Dallas Office
out"
> thanks, Steve
> '{$STAMP BS2p}
> ' declare variable
> result VAR Byte(8)
> idx VAR Nib
> SendData:
> ReadData:
> FOR idx = 0 TO 7
> NEXT
> STOP
> No_Data:
<jwilliams@p...>
byte
> > result VAR Byte(8)
> > idx VAR Nib
> > Read_Data:
> > DEBUG CLS
> > FOR idx = 0 TO 7
> > NEXT
> > STOP
> > -- Jon Williams
> > -- Dallas Office
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > STOP
> > No_Data:
> <jwilliams@p...>
formatted
> > > instruction....
> prevent
embedding
> > that
> > > SendData:
> > not 82.
> > > -- Jon Williams
> > > -- Dallas Office
> > and
> string,
> > I
> > > '{$STAMP BS2p}
> > > ' declare variable
> > > result VAR Byte
> > > SendData:
> > > ReadData:
pin
> > 10,
> > > 'store in
> > variable "result"
> > > 'result = $7C
STOP
> > > No_Data:
> Subject
> > Yahoo! Groups Links
to
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
Steve
need
device is.
> -- Jon Williams
> -- Dallas Office
out"
> thanks, Steve
> '{$STAMP BS2p}
> ' declare variable
> result VAR Byte(8)
> idx VAR Nib
> SendData:
> ReadData:
> FOR idx = 0 TO 7
> NEXT
> STOP
> No_Data:
<jwilliams@p...>
byte
> > result VAR Byte(8)
> > idx VAR Nib
> > Read_Data:
> > DEBUG CLS
> > FOR idx = 0 TO 7
> > NEXT
> > STOP
> > -- Jon Williams
> > -- Dallas Office
> > result VAR Byte
> > SendData:
> > ReadData:
> 10,
> > STOP
> > No_Data:
> <jwilliams@p...>
formatted
> > > instruction....
> prevent
embedding
> > that
> > > SendData:
> > not 82.
> > > -- Jon Williams
> > > -- Dallas Office
> > and
> string,
> > I
> > > '{$STAMP BS2p}
> > > ' declare variable
> > > result VAR Byte
> > > SendData:
> > > ReadData:
pin
> > 10,
> > > 'store in
> > variable "result"
> > > 'result = $7C
STOP
> > > No_Data:
> Subject
> > Yahoo! Groups Links
to
> > abuse@p...
Subject
> Yahoo! Groups Links
> abuse@p...
What often happens in cases like this, is that the instrument
responds too fast, before the Stamp is ready to receive. It takes
the Stamp a good fraction of a millisecond between the time it sends
the "S" and before it is ready to receive its first byte. But the
instrument may only wait a few microseconds. The Stamp has no input
serial buffer. When it is ready, it starts receiving out of sync in
the middle of the response.
In your latest experiment, it would "time out" because it tuned in
too late to get all 8 of the characters it is expecting. Even when
it times out, you can print the string buffer and see if there is
anything recognizable there. It might be garbled, but it will give
you an idea of whether or not my theory is correct.
The setup delay for a SERIN command with a timeout and using the STR
modifier is about 240 microseconds on a BS2sx, and a bit faster on
the BS2p. 600 microseconds on a vanilla BS2.
-- Tracy
You were expecting back the string "7F0000000836A410<CR>", but when
you were only looking for one byte, you got $7f
>thanks, Steve
>'{$STAMP BS2p}
>' declare variable
>result VAR Byte(8)
>idx VAR Nib
>SendData:
>ReadData:
> FOR idx = 0 TO 7
> NEXT
> STOP
>No_Data:
>> result VAR Byte(8)
>> idx VAR Nib
>> Read_Data:
>> DEBUG CLS
>> FOR idx = 0 TO 7
>> NEXT
>> STOP
>> -- Jon Williams
>> -- Dallas Office
>> result VAR Byte
>> SendData:
>> ReadData:
>10,
>> STOP
>> No_Data:
><jwilliams@p...>
>> > instruction....
>prevent
>> that
>> > SendData:
>> not 82.
>> > -- Jon Williams
>> > -- Dallas Office
>> and
>string,
>> I
>> > '{$STAMP BS2p}
>> > ' declare variable
>> > result VAR Byte
>> > SendData:
>> > ReadData:
>> 10,
>> > 'store in
>> variable "result"
>> > 'result = $7C
>> > No_Data:
modifier to put that string into scratchpad memory and save yourself
some space. To learn more click Help|Contents on the menu of the
Stamp editor.
It has been said that SPSTR only works with fixed length strings.
Well, I use it for variable length strings. You can e-mail me at
FrankSmith512@y... if you need to learn how to do that. I only
read a very small amount of the posts. E-mail will be your best bet.
Best Wishes,
Frank
--- In basicstamps@yahoogroups.com, "stenote" <stepnote@c...> wrote:
> back to the books. I need to digest this whole thing and see which
apparently
> Steve
> need
> device is.
> > -- Jon Williams
> > -- Dallas Office
> out"
> > thanks, Steve
> > '{$STAMP BS2p}
> > ' declare variable
> > result VAR Byte(8)
> > idx VAR Nib
> > SendData:
> > ReadData:
> > FOR idx = 0 TO 7
> > NEXT
> > STOP
> > No_Data:
> <jwilliams@p...>
> byte
> > > result VAR Byte(8)
> > > idx VAR Nib
> > > Read_Data:
> > > DEBUG CLS
> > > FOR idx = 0 TO 7
> > > NEXT
> > > STOP
> > > -- Jon Williams
> > > -- Dallas Office
> > > result VAR Byte
> > > SendData:
> > > ReadData:
> > 10,
> > > STOP
> > > No_Data:
> > <jwilliams@p...>
> formatted
> > > > instruction....
> > prevent
> embedding
> > > that
> > > > SendData:
83,
> > > not 82.
> > > > -- Jon Williams
> > > > -- Dallas Office
SERIN
> > > and
result.
> > string,
> > > I
> > > > '{$STAMP BS2p}
> > > > ' declare variable
> > > > result VAR Byte
> > > > SendData:
> > > > ReadData:
> pin
> > > 10,
> > > > 'store in
> > > variable "result"
> > > > 'result = $7C
> STOP
> > > > No_Data:
> > Subject
> > > Yahoo! Groups Links
> to
> > > abuse@p...
> Subject
> > Yahoo! Groups Links
> > abuse@p...
