Serial Communication - Newbie Question
Archiver
i programmed a application with Macromedia Director. I send Integer
between 0-255 to BS2 - nothing happens:
My Code:
'{$STAMP BS2}
'{$PBASIC 2.0}
rpin con 16
bmode con 16468
maxtime con 10000
test var byte(3)
Main:
debug cls, "Input Number: ", CR
serin rpin,bmode,maxtime,timeout,[noparse][[/noparse]test]
debug CR, "Your Input: ",test
if test = "1" then an
if test = "2" then an1
if test = "3" then an2
if test = "4" then aus
if test = "5" then alles
pause 3000
goto main
timeout:
debug"Timeout", CR
pause 1000
goto main
an:
HIGH 0
goto main
an1:
HIGH 1
goto main
an2:
HIGH 2
goto main
aus:
low 0
low 1
low 2
goto Main
alles:
high 0
high 1
high 2
goto main
Ifi send a String, it works.
But i wan't to send a Integer. What must i change in the Code, if the
BS2 recieve Integer's???
Please help
Thx
My Code:
'{$STAMP BS2}
'{$PBASIC 2.0}
rpin con 16
bmode con 16468
maxtime con 10000
test var byte(3)
Main:
pause 3000
goto main
timeout:
debug"Timeout", CR
pause 1000
goto main
an:
HIGH 0
goto main
an1:
HIGH 1
goto main
an2:
HIGH 2
goto main
aus:
low 0
low 1
low 2
goto Main
alles:
high 0
high 1
high 2
goto main
Please help
Thx
serin rpin,bmode,maxtime,timeout,[noparse][[/noparse] DEC test ]
i'm trying to do the same thing with Director, but at the moment i
can't seem to get anything to transfer across, either direction
--- In basicstamps@yahoogroups.com, "plumpi1009" <gplanincic@p...>
wrote:
> Hi,
> My Code:
> '{$STAMP BS2}
> '{$PBASIC 2.0}
> rpin con 16
> bmode con 16468
> maxtime con 10000
> test var byte(3)
> Main:
> pause 3000
> goto main
> timeout:
> debug"Timeout", CR
> pause 1000
> goto main
> an:
> HIGH 0
> goto main
> an1:
> HIGH 1
> goto main
> an2:
> HIGH 2
> goto main
> aus:
> low 0
> low 1
> low 2
> goto Main
> alles:
> high 0
> high 1
> high 2
> goto main
the
> Please help
> Thx
can use the DEC modifier in SERIN to convert the string to a decimal
value:
SERIN Rpin, Bmode, MaxTime, Timeout, [noparse][[/noparse]DEC test]
By using DEC, "1" (ASCII value 49) will be converted to 1. You can
verify this is happening by doing a little test loop (which many users
see unwilling to do when troubles arise). Try this to see if the code
above will be valid:
Test:
SERIN Rpin, Bmode, MaxTime, Timeout, [noparse][[/noparse]test]
DEBUG DEC test
PAUSE 100
GOTO Test
If my assumption is correct, the Test code will display 49 when you have
Director send 1 to the BASIC Stamp.
-- Jon Williams
-- Dallas Office
From: plumpi1009 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kYQPGICupp7QxTsBguD3DCLskPkeYdG_5n-WwdIxNl-wpN1LRQ8V1etQIgS2PRtvD3-OTzX_mRs1alCIIZTgWNsW]gplanincic@p...[/url
Sent: Friday, April 16, 2004 8:30 AM
Subject: [noparse][[/noparse]basicstamps] Serial Communication - Newbie Question
My Code:
'{$STAMP BS2}
'{$PBASIC 2.0}
rpin con 16
bmode con 16468
maxtime con 10000
test var byte(3)
Main:
pause 3000
goto main
timeout:
debug"Timeout", CR
pause 1000
goto main
an:
HIGH 0
goto main
an1:
HIGH 1
goto main
an2:
HIGH 2
goto main
aus:
low 0
low 1
low 2
goto Main
alles:
high 0
high 1
high 2
goto main
Please help
Thx
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
got it.
Thx.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Director may be sending your value as a string. If that's the
case, you
> value:
users
code
> Test:
> DEBUG DEC test
> PAUSE 100
> GOTO Test
have
> -- Jon Williams
> -- Dallas Office
> From: plumpi1009 [noparse][[/noparse]mailto:gplanincic@p...]
> Hi,
> My Code:
> '{$STAMP BS2}
> '{$PBASIC 2.0}
> rpin con 16
> bmode con 16468
> maxtime con 10000
> test var byte(3)
> Main:
> pause 3000
> goto main
> timeout:
> debug"Timeout", CR
> pause 1000
> goto main
> an:
> HIGH 0
> goto main
> an1:
> HIGH 1
> goto main
> an2:
> HIGH 2
> goto main
> aus:
> low 0
> low 1
> low 2
> goto Main
> alles:
> high 0
> high 1
> high 2
> goto main
the
> Please help
> Thx
Subject
> Yahoo! Groups Links
> abuse@p...
