Few Question Help
Hi, I new here. I was require to use a PIC Chip for a project. I
need more info about it.
What is the different between http://www.parallax.com/detail.asp?
product_id=BS2-IC and http://www.parallax.com/detail.asp?
product_id=27290
Correct me if I'm wrong. BASIC Stamp 2 OEM Module is everything is
inside ready to program through the serial port, which BASIC Stamp 2
Module (Chip Only) require a trainer board to program it. Yes or no?
For the "BASIC Stamp 2 OEM Module" once the instruction is write in
the EEPROM memory. To use it in a standalone do I just add 5V to vdd
and Vss for ground?
Thank you
product_id=27290
and Vss for ground?
Thank you
a 24-pin 'DIP' (Dual in-line package). It plugs
in to a board and takes up little space. There
are several prototype boards available that it
plugs into, for completed projects.
The OEM package has a 'SIP' interface on it.
It also looks like the programming connector
is built-in on the OEM version, where you are
right, the 24-pin DIP requires a few wires to
connect to a DB-9 connector.
The OEM package has a full LM2940-5 regulator
on it -- which means the package is probably
good to 1000 mA, where the BS2 is more limited.
You'll still have to fabricate a connector for
power, though.
Still, what you have said seems to be correct.
You should know that the BS2 is only nominally
a PIC processor. True, it uses a PIC, but that's
to implement its PBasic language interpreter.
And yes, the PBasic program is compiled by the
IDE into tokens, and stored in the on-board
EEPROM, so it runs when power comes up. It's
a very nice package, but you may want to check
with your instructor if it meets his requirements.
To power it, you can put 6V to 12V on VIN, or
+5 V on VDD. Of course, Ground must also be
connected to VSS.
--- In basicstamps@yahoogroups.com, "blue96813" <blue96813@y...>
> product_id=27290
2
vdd
> and Vss for ground?
> Thank you
control). As you point out, the BS2 module is needs to be placed in a
circuit to provide power and programming connections. With the OEM
module, you can plug into a breadboard, provide power (it has an onboard
regulator) and then plug your programming cable right into its DB-9.
If you just want to workout projects on a large solderless breadboard,
the OEM module is an excellent way to go. If you ultimately want to
enclose the BASIC Stamp in a finished project, the standard module is
probably the better choice.
-- Jon Williams
-- Dallas Office
From: blue96813 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lC-jR9WL9xj_7otB1EQMqWTiHLZ7zM16Gyt_3mHyTUqP-VFKSOd065TUX2L30O5stH8n6RdWJwVM]blue96813@y...[/url
Sent: Friday, April 16, 2004 1:00 AM
Subject: [noparse][[/noparse]basicstamps] Few Question Help
product_id=27290
and Vss for ground?
Thank you
