temperature sensors, and method to varify rpm
any sugestions on temperature sensors, i need to pick a sensor to
monitor a tiny gas engine, from normal operating temps of about 100 -
350 degrees f , any sugestions?
also i want to have a sensor to read flywheel rpm, is there a way to
do this by driling one hold and using ir sensors?
> pick a sensor to
We are having the same problem for a motorcycle. We
need to get the Temp of the engine, but don't have
factory specs for an OEM part or on-board sending
unit, so we're considering an external part. If you
find something, please post your findings, and we will
do like-wise.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online by April 15th
http://taxes.yahoo.com/filing.html
works fine with a BS2p stamp but uses a lot or variable memory.
Another idea may be to use a infared sensor(RAYTEX) to read the temperatures
you want to monitor. This is a handheld device so it won't send info to a
stamp or computer.
Bill Lynn
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7ZTXzNLPIOQ4cQLwgtgUQrSdYg1hS38ZVgzfT0vKcjakfhH5L2IuuiAIPA2GVLKD8_H2gzpQJ503K5ml2tc]knight_designs@y...[/url
Sent: Friday, April 16, 2004 5:51 PM
Subject: Re: [noparse][[/noparse]basicstamps] temperature sensors, and method to varify rpm
> pick a sensor to
do like-wise.
Knight Designs
(607) 535-6777
Do you Yahoo!?
Yahoo! Groups Links
