VB6 / MSCOMM control - serial comm echo
I have a Visual Basic 6 program which connects with a BS2 stamp
using the serial port on the Board of Education.
The VB6 program uses the MSCOMM control and the OnComm event. I know
that pins 6 and 7 on the BOE are connected to handle automatic
serial port selection in the stamp editor.
Why does data send to the BS2 from the VB6 program get returned to
the VB6 program OnComm/CommEvent (comEvReceive)?
This occurs even if there is no power to the BS2 (unless the serial
cable is disconnected). I thought it might be the two capacitors on
the ATN (serial pin 4) line, but that doesn't seem to be the case.
Here are the MSCOMM properties
MSComm1.CommPort = 1
MSComm1.DTREnable = False
MSComm1.EOFEnable = False
MSComm1.Handshaking = comNone
MSComm1.InBufferSize = 1024
'Setting the InputLen property to 0 causes the
'Communications control to read the entire contents
'of the receive buffer when the Input property is used
MSComm1.InputLen = 1
MSComm1.InputMode = comInputModeText
MSComm1.NullDiscard = False
MSComm1.ParityReplace = "?"
MSComm1.RThreshold = 1
MSComm1.RTSEnable = False
MSComm1.SThreshold = 1
MSComm1.Settings = "9600,n,8,1"
Thanks for any insight.
- Ron
- Ron
"borrows" power from the RS-232 connection, so everything gets echoed
back. This is easy to filter, or it can be used (as the compiler does)
to make sure that a byte sent to the BASIC Stamp actually got there (you
know that since it got echoed).
-- Jon Williams
-- Dallas Office
From: Ron Czapala [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aUhRP1JhQjKGbZ8NyQ5jY2aREZG5GEq5zf4D6I8ztqH5AlsEsSnKtnxnOuyGqWWOUblCeW6LDWTx]rczapala@y...[/url
Sent: Thursday, April 15, 2004 3:37 PM
Subject: [noparse][[/noparse]basicstamps] VB6 / MSCOMM control - serial comm echo
- Ron
I wondered whether the BS2 was drawing power from the PC serial
port. That explains why it worked with no power applied. I'm not
sure what the "level shifter" is but I assume it is in the PIC
controller and that there is no way to disable the echo in PBasic.
Thanks for your help!
- Ron
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> The reason for this is that the level-shifter on the BS2 module
echoed
does)
there (you
> -- Jon Williams
> -- Dallas Office
> From: Ron Czapala [noparse][[/noparse]mailto:rczapala@y...]
know
serial
on
> - Ron
and TTL levels of the core micro.
-- Jon Williams
-- Dallas Office
From: Ron Czapala [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5MdK2SBeHSQrRslfPfrtaCy3-cZWqd-ThVErm9wDcCoamb--b3lDUoIsnrO2RlskiwI0yKPcb-h80c2k]rczapala@y...[/url
Sent: Thursday, April 15, 2004 6:56 PM
Subject: [noparse][[/noparse]basicstamps] Re: VB6 / MSCOMM control - serial comm echo
Thanks Jon!
- Ron
echoed
does)
there (you
> -- Jon Williams
> -- Dallas Office
know
serial
on
> - Ron
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
handles the 12v to 5v difference.
Thanks again.
- Ron
wrote:
> No, a level shifter takes care of the interface between RS-232
levels
> -- Jon Williams
> -- Dallas Office
> Thanks Jon!
> - Ron
<jwilliams@p...>
> echoed
> does)
> there (you
> > -- Jon Williams
> > -- Dallas Office
> know
to
> serial
> on
case.
> > - Ron
Subject
> Yahoo! Groups Links
> abuse@p...
should be easy to filter out the echo, but it would be even easier
if it could be disabled...
thanks,
Alex
--- In basicstamps@yahoogroups.com, "Ron Czapala" <rczapala@y...>
wrote:
> Thanks Jon!
> - Ron
<jwilliams@p...>
> echoed
compiler
> does)
> there (you
> > -- Jon Williams
> > -- Dallas Office
> know
to
> serial
> on
case.
> > - Ron
The only way to disable this would be by removing the 4.7k
resistor across Sin (pin 2) and Sout (pin 1). On the Stamp-IC it is not
easy but the OEM stamp it's not to bad. Also it will need to be
reinstalled when wanting to reprogram the stamp.
Stephen Swanson
Technical Support Manager
599 Menlo Drive, #100
Rocklin, CA 95765
Phone (916) 624-8333
E-mail ..... sswanson@p...
Main site...... www.parallax.com
Educational site.... www.parallax.com/sic
Javelin Stamp... www.parallax.com/javelin
From: lexaay [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1TkusyRJ5pl_j34qzSiFf41p7s4xcfdwVtXbqFG3qVp-lIlEODWoH9M16C7AwZkmndh7xshzCqhY93W3]lexaay@y...[/url
Sent: Monday, April 19, 2004 9:50 AM
Does anyone know if its possible to disable the echo? I suppose it
thanks,
Alex
wrote:
> Thanks Jon!
> - Ron
<jwilliams@p...>
> echoed
compiler
> does)
> there (you
> > -- Jon Williams
> > -- Dallas Office
> know
to
> serial
> on
case.
> > - Ron
Yahoo! Groups Links
abuse@p....
on the BS2 using the 'TX' line voltage for its
transistor-based 232. The BS2 'RX' line (which
actually sends data from the BS2) uses the PC's
'TX' line for +12 volts. Thus, when the PC
sends data, and drops its +12 volt TX, this
immediately appears on the PC's 'RX' line.
It's in hardware. It can't be defeated. It's
a clever trick, which allows the BS2 to talk
'true' +-12 volt RS-232, without actually
having a 12 volt supply on-chip.
It has the nice side-effect that the PC can
tell every byte has made it to the chip,
since every byte it sends is echo'ed back.
And it is usually not too hard to have
the PC 'toss' the echo to its own messages.
> thanks,
> Alex
> wrote:
> > Thanks Jon!
PBasic.
> > - Ron
> <jwilliams@p...>
> > echoed
> compiler
> > does)
> > there (you
> > > -- Jon Williams
> > > -- Dallas Office
> > know
> to
> > serial
capacitors
> > on
> case.
> > > - Ron
debug for serial input and output on the stamp. You can use any of the
ports for serial I/O and they will not 'echo'. For example,
http://www.geocities.com/jimforkin2003/
jim
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZHZDCinwV7UgDVdNvUgmLzYbfJz8pfSCnkGrusCFXMR1p3_Dt_BZ4hv7E4bdR7XaAZbr9F-xaMu9rzL3WzMsCyesZhA]allan.lane@h...[/url
Sent: Monday, April 19, 2004 1:45 PM
Nope, the 'echo' is caused by the RS232 circuitry
> thanks,
> Alex
> wrote:
> > Thanks Jon!
PBasic.
> > - Ron
> <jwilliams@p...>
> > echoed
> compiler
> > does)
> > there (you
> > > -- Jon Williams
> > > -- Dallas Office
> > know
> to
> > serial
capacitors
> > on
> case.
> > > - Ron
Yahoo! Groups Links
switch to SERIN/SEROUT on standard IO pins, but then you may need to
level-shifter.
-- Jon Williams
-- Dallas Office
From: lexaay [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6SuSGOX9tO_vS1vSqJOOu7O0ZwvrWZms1BxXs71tBTr98nMwWbuLAZRupXLx_H7QicVxFRjnv4egqQ]lexaay@y...[/url
Sent: Monday, April 19, 2004 11:50 AM
thanks,
Alex
wrote:
> Thanks Jon!
> - Ron
<jwilliams@p...>
> echoed
compiler
> does)
> there (you
> > -- Jon Williams
> > -- Dallas Office
> know
to
> serial
> on
case.
> > - Ron
Yahoo! Groups Links
abuse@p....
It's not really a problem. As Jon said it is easy to ignore the
echo data. I was just trying to understand why it was happening.
- Ron
--- In basicstamps@yahoogroups.com, "Stephen Swanson"
<sswanson@p...> wrote:
> Hello,
is not
> Stephen Swanson
> Parallax, Inc.
> Rocklin, CA 95765
