Counting voltage Spikes
I want to count every time the voltage goes above 1 volt. I have a
BS II and a ADC0804 Annalog to digital converter, but I am a nubie to
all this. Can somebody give me some advice.
I am not set on using the BS II or the ADC0804 if anybody knows an
easier way to accomplish this please tell me.
Thank you,
Nick
Thank you,
Nick
above 1 volt, and have the output of the op-amp comparitor trigger a 555 timer
configured to monostable mode (one-shot) with an output pusle of 10 mS or so.
But this 10 mS time may be too long depending on how often your voltage spike
occur.
Do you know how often the voltage spike will occur?
If you need further help with any aspect of this, write back
ken
Thank you,
Nick
> nubie to all this. Can somebody give me some advice.
Much depends on the characteristics of the signal in
question. "Spikes" are generally short duration - a few nanoseconds
to perhaps tens of nanoseconds. That is way too short for many A/D
converters to produce a result much less for a relatively slow
microcontroller to respond. If you mean "pulses" which are typically
longer you may be able to accomplish your goal using the BS2 but I
would suggest that the A/D converter is not necessary unless you also
need to know the magnitude of the pulse as opposed to just
above/below the threshold.
Secondly, there is the issue of the repetition rate. If the spikes
or pulses happen faster than the microcontroller is able to register
them you'll be unsuccessful. In this case, you might be able to add
an external counter which will accumulate a count of the pulses that
occur. The Stamp can reset the counter, wait for a period of time
and then read the counter to get a measure of the average frequency
of the pulses.
Lastly, if the 1V threshold is important, you'll likely want to use a
comparator so that you can get logic levels representing over/under
conditions. Moreover, you probably also want the comparator to have
hysteresis to avoid false logic transistions when the signal is near
the threshold. How much hysteresis you need depends on the signal's
rate of change and how noisy (electrically) the environment is. For
example, you might add hysterisis that causes the comparator to
output logic 1 when the input is above 1.25 volts but doesn't change
back to logic 0 until the input falls below 0.75 volts. Perhaps 0.9V-
1.1V is the right amount of hysteresis. You'll have to decide.
frequency and duration and the expected pulse characteristics in
general.
At a minimum, if you can count pulses that are 1.3 volts threshold
instead of 1 volt, you might just feed them into a stamp input, and
use its built-in 1.3 volt threshold and the COUNT command. If the
signal is noisy, you might have to add an RC filter. If the 1 volt
threshold is necessary, you might be able to couple the signal in
through a capacitor.
The ADC will be useful only for very long events, not "spikes" in the
way we usually think of that term.
And it is a different thing if the spikes only occur once every hour,
or if they occur a million times a second. Or if you have to
distinguish between those that are 0.99 volt and others are 1.01
volt. More detail please.
>Thank you,
>Nick
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
have inquired further about the characteristics of my "spike". I may
be using the term incorrectly, but what I mean by a "spike" is
probably more of an irratic distrubance (very noisy). This
distrubance occurs at a variable rate. When viewed on a scope this
signal looks like a big blob of fluctuating voltage (-1.4v to
+1.4v). It lasts any where from 3 seconds to .003 second (depending
on the rotational speed of my water velocity meter).
Sombody mentioned the concept of hysteresis. This is something that
I am strongly considering but don't understand. I was thinking of
using a Schmitt trigger to help me count these repetitious voltage
disturbances, but I really don't know much about them. It is my
symplistic understanding that a Schmitt trigger could be turned on at
a set voltage and turned off a a set voltage. This would be good!
In any case I plan on using a diode to constrain the voltage to
positive values.
I would greatly appreciate continued advice regarding this problem.
Thank you,
Nick
> I was thinking of using a Schmitt trigger to help me count these
> repetitious voltage disturbances...
A Schmitt trigger is a comparator with hysteresis. You still have to
decide what the transition voltage will be and choose the resistor
values to realize them. This link may help.
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/schmitt.html
If your signal is noise as you describe, the transitions are likely
to be much too fast for a BS to respond to them individually. You
may need external circuitry to count them as I mentioned earlier.
