Highnib - lownib problem
Hello Stampers,
It's been a while.......
My problem:
I define variables:
reg var byte(10) 'define a 10 byte array called reg
red var nib 'define a 4 bit variable
green var nib 'define anothet 4 bit variable
I want to fill the first byte of the array so that the four MSB's contains
"red" and the four LSB's contains "green"
reg(0).highnib = red
reg(0).lownib = green
After tokenizing I get an error on the reg(0).highnib line
expected "=" instead of the "."
Sombody knows the problem....?
Thanx
Michel De Meester
Met vriendelijke groetjes,
> Michel De Meester
> Biotechnisch Onderhoud
> Universitair Ziekenhuis Antwerpen
> Wilrijkstraat 10
> 2650 Edegem - B
> tel: ++32 (0)3 821 36 47
> e-mail: michel.de.meester@u...
My problem:
I define variables:
Thanx
Michel De Meester
> Michel De Meester
> Wilrijkstraat 10
> 2650 Edegem - B
>Hello Stampers,
>My problem:
>I define variables:
Try this:
reg.HIGHNIB(0) = red
reg.LOWNIB(0) = green
>Thanx
>Michel De Meester
>> Michel De Meester
>> Wilrijkstraat 10
>> 2650 Edegem - B
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
> Try this:
Indead, I overlooked this in the manual.
After reading page 54 and 55 I think it should be:
reg.LOWNIB(1) = green
because the variable is addressed as nibble.
So, if I want to fill the 10 byte array with nibbles I need to use
indexes from 0 to 19 (assuming all the "color" variables are nibbles)
'byte0
'byte1
reg.HIGHNIB(2) = purple
reg.LOWNIB(3) = orange
'byte9
reg.HIGHNIB(18) = any color
reg.LOWNIB(19) = any color
Am I right?
Michel De Meester
your case you could do this:
reg(0) = (red << 4) + green
-- Jon Williams
-- Dallas Office
From: De Meester, Michel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tB5Huzyq3kSDl9HzTkTt6jBJYiNvx09pZ22YpWAmGVfRWBrDAiYRImWYH4eF8j2QE-i9TjY1Nk4FSaFaZEqjt99q0HAdob0A]Michel.De.Meester@u...[/url
Sent: Wednesday, April 14, 2004 5:47 AM
To: 'basicstamps@yahoogroups.com'
Subject: [noparse][[/noparse]basicstamps] Highnib - lownib problem
Hello Stampers,
My problem:
I define variables:
contains "red" and the four LSB's contains "green"
Thanx
Michel De Meester
both of those address the same nib. The first one is an offset zero
from HIGHNIB, which is the same as HIGHNIB. The second one is an
offset one above LOWNIB, which too is HIGHNIB.
If you want to address this as an array of nibbles, use either the
one Bruce suggested:
reg.LOWNIB(0) = green ' offset zero from LOWNIB
reg.HIGHNIB(0) = red ' offset zero from HIGHNIB
or this alternative:
reg.LOWNIB(0) = red ' offset zero from LOWNIB
reg.LOWNIB(1) = green ' offset one from LOWNIB
for all of them:
FOR idx=0 to 18 STEP 2
reg.LOWNIB(idx) = red ' offset idx from LOWNIB
reg.HIGHNIB(idx) = green ' offset idx from HIGHNIB
NEXT
-- Tracy
>Hello Bruce,
>> Try this:
>'byte0
>'byte1
>'byte9
>Am I right?
>Thanks
>Michel De Meester
