searching archives
hi
Anyone know of a way to search all of the messages at once?
Or is there a download available of all archived messages so you can
search it with another application?
Bruce
Bruce
select the BASIC Stamps group.
-- Jon Williams
-- Dallas Office
From: etech500 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=f0v0PQbP03CQsdjJmFYFxHdX8KL_GmGz8iQLFWqbgis7Tn9lSwhyFF71PhCy0TkQjXSr99ut0LxP07Q]bmwbruce@a...[/url
Sent: Wednesday, April 14, 2004 12:35 AM
Subject: [noparse][[/noparse]basicstamps] searching archives
hi
Bruce
I search for a subject it only searches a few messages at a time.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You can search the archives at Yahoo Groups. You need to log in and
> -- Jon Williams
> -- Dallas Office
> From: etech500 [noparse][[/noparse]mailto:bmwbruce@a...]
> hi
can
> Bruce
Al Williams
AWC
* Easy RS232 Prototyping:
http://www.awce.com/rs1.htm
From: hodgebrad [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qai3-T25dMyTd4m_QNPpZ0txvrr6USp0RMDwFqBgOZtxfyajZhc280NrqeU3h9cPHHv17EGYxX8XzzT1Cg]HodgeBrad@b...[/url
Sent: Wednesday, April 14, 2004 3:39 PM
Subject: [noparse][[/noparse]basicstamps] Re: searching archives
Yes, but how do you search all of the archives at one time. Now, if
> -- Jon Williams
> -- Dallas Office
> hi
can
> Bruce
Yahoo! Groups Links
that I could alter the START position. I would assume there is a URL command
line provision to supply the END position.
In the example below I just altered the URL and was able to change the START
to whatever I wanted. In the case below it was 40000. Anything out of range
such as -1 or a number higher than the number of messages seems to default
to the highest message number.
http://groups.yahoo.com/group/basicstamps/messagesearch/40000?query=Schwabe
...If all else fails contact yahoo and ask them if you or someone else
does not find a URL hack.
>This is a recent change that Yahoo made. I don't know of any way around it.
>Regards,
>Al Williams
>AWC
>From: hodgebrad [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zouR9k0eHHTG6eXDkjMeKm5O7qScSimwkdW6ro-YqQEYFH4fgdFiVFV4TSv-_eC4fqKsj_8Oyj4qUaaF]HodgeBrad@b...[/url
> > -- Jon Williams
> > -- Dallas Office
> > hi
>can
> > Bruce
Beau Schwabe Mask Designer National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Home: polygon_man@h... Mail Stop GA1
Work: bschwabe@a... Norcross, GA 30071
wrote:
> This has got to be a syntax issue... I poked around a little bit
and found
URL command
the START
out of range
default
This is correct. if one were to replace Schwabe for the search
string and the 40000 with where they want to start, Yahoo will treat
it as it Yahoo did it. In other words, start there and allow the
user to keep hitting next.
Yahoo changed the way they search when they elminated storage of
attachements.
Now it is the last 250 records or the first 50 matches, whichever
comes first.
I wrote a nice long and comprehensive post that I was going to add to
the files section, but oddly enough, It has yet to be posted.
Another solution is PGOffline, a low cost Yahoo List program that
allows you to copy an entire list to your machine and search at will.
The problem falls back to Yahoo again. They limit you to views per
hour so the 43,000 records we have now will take some days to pull.
Nice thing is that users can work at sections and cut that down, as
sections can be combined.
Dave
If I'd know you were doing this sort of stuff I'd have been picking your brains about it. I'm doing a PIC based 2 channel data logger. Anyway I've spent the last couple of days DL'ing basicstamps and the resultant archives are here:
http://www.pgoffline.com/groupmanager/basicstamps-1.zip 13.8 Mb (messages 1 - 20000)
http://www.pgoffline.com/groupmanager/basicstamps-2.zip 19.0 Mb (messages 20001 - 43581)
The application is here:
http://www.pgoffline.com/groupmanager/PGOffline-2-0-179.exe
homepage here: http://www.pgoffline.com
$15.99 after 30 day trial. Don't like it? Chuck it & keep the archives (in standard MS Access format).
Cheers,
Wilson Logan (PGOffline creator).
