BS2p variable stuck
Hi
I have narrowed a problem down to stuck variable(s) (true) in a
program.
I had prev. thought it to be an input problem, but now have the input
and outside world isolated except for my output pin.
any label like this,
label VAR Bit is always true even if I write label = 0
program is runing ok, debug shows the problem and my IF label Then is
showing that the label is true.
any ideas? bad stamp?
Bruce
program.
Bruce
No, I'm pretty sure it's not a bad Stamp. I'm quite certain it's a
programming error. Put this bit of code just after your declarations
(before ANY code can run) and you should see the bit flipping
back-and-forth.
Test:
DEBUG HOME, BIN1 label
label = ~label
PAUSE 500
GOTO Test
-- Jon Williams
-- Dallas Office
From: etech500 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Oe5dJ2_GUOo4eyjmlBrPO81CnU_iKrBEYUIQYl_ZIXvVIdlPaG-3_dhIc7ygo2w4fz6BLaR8]bmwbruce@a...[/url
Sent: Tuesday, April 13, 2004 1:47 PM
Subject: [noparse][[/noparse]basicstamps] BS2p variable stuck
Hi
program.
Bruce
bmwbruce@a... writes:
> program.
Try renaming your label variable to label1
Sid
I have improved on it by getting my MAINIO and AUXIO statements in
place and now I have control from a switch but DEBUG still says it is
always true even when input is gnd and the label is performing
correctly as false in my IF statements. oh, well I'll post more as
I fix it. Can't have too much info in the archives ya know
Bruce
--- In basicstamps@yahoogroups.com, "etech500" <bmwbruce@a...> wrote:
> Hi
> program.
input
is
> Bruce
Posting your errant code would probably lead to a quicker solution.
-- Jon Williams
-- Dallas Office
From: etech500 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kPgrinfpdyOe3ZhHOAD1rBpMCHDwM5jxe0emjusbC8M4n88ZtzLPnkJfzmHZUN2-7YKZgSZdXBOJ9A]bmwbruce@a...[/url
Sent: Wednesday, April 14, 2004 12:29 AM
Subject: [noparse][[/noparse]basicstamps] Re: BS2p variable stuck
thanks for info,
Bruce
> Hi
> program.
input
is
> Bruce
MAINIO, AUXIO in the right places and also having the debug's in the
right places for the program flow.
Part of the problem was writing too much code and trying to debug it.
Bad code can really present some weird problems, I always learn the
hard way.....
This basic stamp stuff is really cool.
Bruce
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Bruce,
> -- Jon Williams
> -- Dallas Office
> From: etech500 [noparse][[/noparse]mailto:bmwbruce@a...]
> thanks for info,
is
as
> Bruce
wrote:
> > Hi
> > program.
> input
> is
> > Bruce
