SuperCarrier Cpacitors? — Parallax Forums
edited 2004-04-13 17:18 in General Discussion
I have a BS2p24 and SuperCarrier board:
http://www.parallax.com/dl/docs/prod/schem/supercarrierbd.pdf
I note that there are two 0.1uF capacitors(C3&4) in the serial connection
to the board.
On the schematic for the BS2p24:
http://www.parallax.com/dl/docs/prod/schem/Bs2p24revB.pdf
these capacitors are *not* present.
I am building a custom pc board for my BS2p24 and need to know
if these caps are necessary for normal serial comm to the
Stamp. I would prefer to delete them if possible.
Tom Fisher
Dallas,TX
    edited 2004-04-13 15:42
    The caps aren't required if you're ONLY using the BASIC Stamp editor
    because the editor deals with the DTR line properly -- it doesn't hassle
    the BASIC Stamp module. But ... other programs are not as well behaved
    and will cause problems (notably HyperTerminal).
    The caps cost just a few cents and don't require a lot of PCB real
    estate, so adding them would be a very good idea.
    -- Jon Williams
    -- Dallas Office
    From: tboonefisher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rQPPrwN6Um42waayh9kqeW5U7z5DMB5NYJciZ_Qot0tRsJWtqX1FJqUmsqat1xwQOb_AdKpK5a7-unFxopKV]tboonefisher@s...[/url
    Sent: Tuesday, April 13, 2004 9:37 AM
    To: Support
    Cc: basicstamps@yahoogroups.com
    Subject: [noparse][[/noparse]basicstamps] SuperCarrier Cpacitors?
    connection to the board.
    I am building a custom pc board for my BS2p24 and need to know if these
    Tom Fisher
    Dallas,TX
    edited 2004-04-13 15:58
    The BS2 IDE uses the DTR line to reset the
    BS2 just before it programs it. Holding the
    DTR line 'active' keeps the BS2 in RESET,
    unless these two capacitors are there.
    When they are there, DTR going active gives
    a 'pulse' which does reset the BS2, but
    then lets it run.
    If you can control the DTR line, and force
    it to stay 'inactive', then you don't need
    the two caps. Note that Hyperterm is a
    very stubborn program, and insists on
    keeping DTR active -- so without the caps,
    Hyperterm holds the BS2 in RESET.
    If you disconnect DTR entirely, you won't
    be able to program the BS2 in-circuit from
    the BS2 IDE -- but it will run with
    Hyperterm.
    It's really much safer and more robust to
    leave the caps in.
    --- In basicstamps@yahoogroups.com, "tboonefisher"
    connection
    > to the board.
    > Thanks,
    > Tom Fisher
    > Dallas,TX
    edited 2004-04-13 17:15
    Thanks, Jon.
    Tom Fisher
    > then lets it run.
    > Hyperterm.
    > leave the caps in.
    Thanks for a VERY nice explanation.;-))
    Tom Fisher
    Dallas,TX
