Sumo won''t turn and moves slowly
Just for clarification, while the TAB Sumo robot uses a BASIC Stamp
microcontroller, it was not designed nor is it officially supported by
Parallax (it's not a Parallax product). Of course, we'll help where we
can with general programming questions, but specific support for that
robot should be addressed to the vendor or dedicated support forums as
Alan pointed out below.
-- Jon Williams
-- Dallas Office
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=91is6EW3WS28gEtLypzkAmr60_eMH4_ePiqSH46-nj2xQ9l-QhlNCg8XOmKjqDrr5v6uL8x6K_N-tyY7maz_ryhX8A]allan.lane@h...[/url
Sent: Monday, April 12, 2004 12:36 PM
Subject: [noparse][[/noparse]basicstamps] Re: Sumo won't turn and moves slowly
Eliza, is the name "TAB" on the box for your
SumoBot? The TAB publishing company has made a
"Sumobot" package -- that uses the BasicStamp 2,
so you're still in the right place. The TAB
robot does have 4 wheels, and a rubber o-ring
as a 'tread'.
If so, you should aslo check out the 'tabrobot'
forum. The TabRobot uses a 'co-processor' to
control its wheel motors, and they'll have info
on that on the other forum.
--- In basicstamps@yahoogroups.com, Eliza Yasmin <eliza_yasmin@y...>
wrote:
> Hello Gregg and Jon,
> Thanx for the info. As I am new in BASIC Stamp, I've
> been searching for documents on how to program a
> SumoBot and I've downloaded the SumoBot Manual in
> Parallax's page and read through the document. I
> started out with Experiment #2: SumoBot Locomotion.
> Refering to page 12, I loaded the example program
> given which will test the SumoBot's motors. I was
> hoping to see a correct output but the robot went the
> way i mentioned earlier.
> I noticed that the SumoBot in the Parallax's page is different from
> mine. Mine has 4 wheels and an on-off power switch instead of a
> three-position power switch. Can I still refer the manual? I would
> appreciate some guidance. [noparse]:)[/noparse]
> Thanx!
-- Jon Williams
-- Dallas Office
as a 'tread'.
> Thanx!
