Sumo won''t turn and moves slowly
Eliza, is the name "TAB" on the box for your
SumoBot? The TAB publishing company has made a
"Sumobot" package -- that uses the BasicStamp 2,
so you're still in the right place. The TAB
robot does have 4 wheels, and a rubber o-ring
as a 'tread'.
If so, you should aslo check out the 'tabrobot'
forum. The TabRobot uses a 'co-processor' to
control its wheel motors, and they'll have info
on that on the other forum.
--- In basicstamps@yahoogroups.com, Eliza Yasmin <eliza_yasmin@y...>
wrote:
> Hello Gregg and Jon,
> Thanx for the info. As I am new in BASIC Stamp, I've
> been searching for documents on how to program a
> SumoBot and I've downloaded the SumoBot Manual in
> Parallax's page and read through the document. I
> started out with Experiment #2: SumoBot Locomotion.
> Refering to page 12, I loaded the example program
> given which will test the SumoBot's motors. I was
> hoping to see a correct output but the robot went the
> way i mentioned earlier.
> I noticed that the SumoBot in the Parallax's page is
> different from mine. Mine has 4 wheels and an on-off
> power switch instead of a three-position power switch.
> Can I still refer the manual? I would appreciate some
> guidance. [noparse]:)[/noparse]
> Thanx!
> --- Gregg C Levine <hansolofalcon@w...>
> wrote:
> > Hello from Gregg C. Levine
> > Very astute of you, Jon.
> > But as you might have noticed, I mentioned that
> > there are three
> > different kinds of PWM output, one is indeed for
> > servomechanisms, such
> > as the ones worn by the robot, and the next one is
> > for the DC motor
> > drive systems, which is indeed not used here, and
> > the third is the
> > rarely used power supply systems.
> > Without seeing the code being used, I suspected at
> > first that the
> > fault lay within the construction of the PWM
> > statements. I now believe
> > my earlier belief to be an accurate one, in view of
> > your earlier
> > statements. However, to confirm this analysis what
> > we need to see is
> > the complete code. I suggest that it should be
> > posted.
> > Gregg C Levine hansolofalcon@w...
> > "The Force will be with you...Always." Obi-Wan
> > Kenobi
> > "Use the Force, Luke."· Obi-Wan Kenobi
> > > From: Jon Williams [noparse][[/noparse]mailto:jwilliams@p...]
> > > Sent: Sunday, April 11, 2004 1:47 PM
> > > To: basicstamps@yahoogroups.com
> > > Subject: RE: [noparse][[/noparse]basicstamps] re: Sumo won't turn and
> > moves slowly
> > > The SumoBot uses servos for locomotion so it
> > doesn't use the kind of
> > PWM signal
> > > intended for DC motors.
> > > -- Jon Williams
> > > -- Applications Engineer, Parallax
> > > -- Dallas Office
> > > From: Eliza Yasmin [noparse][[/noparse]mailto:eliza_yasmin@y...]
> > > Sent: Sunday, April 11, 2004 12:02 PM
> > moves slowly
> > > Hello Gregg,
> > > Looks like this topic is very new to me. My
> > question
> > > is related to the SumoBot. I'm new with the robot
> > as
> > > well. Can someone assist me on my problem? Besides
> > > that, I'll also look up for PWM.
> > > Thanx.
> > > --- Gregg C Levine
> > > wrote:
> > > > Hello from Gregg C Levine
> > > > PWM - Pulse Width Modulation. It's used for DC
> > motor
> > > > drive systems.
> > > > That includes servomechanisms. Some power
> > supplies
> > > > use it as well.
> > > > Before we get into a semi-on-topic discussion
> > here,
> > > > as this only
> > > > partly applies to the Stamps, I suggest you
> > check
> > > > this subject out via
> > > > your public library.
> > > > Kenobi
> > > > > From: Eliza Yasmin
> > > > > Sent: Sunday, April 11, 2004 12:15 PM
> > > > > Subject: Re: [noparse][[/noparse]basicstamps] re: Sumo won't turn
> > and
> > > > moves slowly
> > > > > Dear George,
> > > > > I can't understand what u are saying. What is
> > PWM?
> > > > Can
> > > > > u pls explain in details.
> > > > > Thanx.
> > > > > --- George Warner <geowar@a...> wrote:
> > > > > > > I have porgrammed a SumoBot to move
> > forward
> > > > then
> > > > > > turn right. The
> > > > > > > problem is, the robot won't turn right as
> > if
> > > > the
> > > > > > robot is heavy. But
> > > > > > > when I lift the robot, one wheel stop then
> > the
> > > > > > other moves (I assumed
> > > > > > > the robot is doing what it is told). What
> > > > might
> > > > > > cause this to happen?
> > > > > > > I also have another problem. When the
> > robot
> > > > moves
> > > > > > forward, it would
> > > > > > > stop sometimes. When I push a bit, the
> > robot
> > > > would
> > > > > > moves again but
> > > > > > > slowly. Is there something wrong with the
> > > > coding?
> > > > > > > Appreciate ur help. Thanx in advance.
> > > > > > I've actually seen this happen when you're
> > > > sending
> > > > > > the PWM to the servo's
> > > > > > too often (or not often enough).
> > > > > > Enjoy,
> > > > > > George Warner,
> > > > > > Schizophrenic Optimization Scientists
> > > > > > Apple Developer Technical Support (DTS)
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed.
> > Text in the Subject and Body of the message will be
> > ignored.
> > Yahoo! Groups Links
> __________________________________
> Do you Yahoo!?
> Yahoo! Tax Center - File online by April 15th
> http://taxes.yahoo.com/filing.html
as a 'tread'.
> Thanx!
> > there are three
> > for the DC motor
> > the third is the
> > first that the
> > your earlier
> > we need to see is
> > posted.
> > Kenobi
> > moves slowly
> > PWM signal
> > > -- Jon Williams
> > > -- Dallas Office
> > moves slowly
> > > Hello Gregg,
> > question
> > as
> > > Thanx.
> > > --- Gregg C Levine
> > motor
> > > > drive systems.
> > supplies
> > > > use it as well.
> > here,
> > > > as this only
> > check
> > > > Kenobi
> > > > > From: Eliza Yasmin
> > and
> > > > moves slowly
> > > > > Dear George,
> > PWM?
> > > > Can
> > > > > Thanx.
> > forward
> > > > then
> > > > > > turn right. The
> > if
> > > > the
> > > > > > robot is heavy. But
> > the
> > > > might
> > robot
> > > > moves
> > > > > > forward, it would
> > robot
> > > > would
> > > > > > moves again but
> > > > coding?
> > > > sending
> > > > > > Enjoy,
> > > > > > George Warner,
> > ignored.
> > Yahoo! Groups Links
> Do you Yahoo!?
