How do I poll for serial input AND check for button changes at the same time
If you want to keep the value of the switches while waiting for serial
input you will have to have a latch of some sort. You could use a
74C922 keyboard encoder to handle a group of pushbuttons. You could
actually use a 16 key keyboard or wire your individual switches as
such. It has debounce circuitry and a latch and a signal that tells
you when a key was pressed. You will also use fewer I/O pins. Some
people think these are a bit expensive @$7.00 but I think they are a
great time saver. Good luck.
Lee Harker
--- In basicstamps@yahoogroups.com, "Josh Polk" <mcstampfunk3@y...>
wrote:
> I don't know if this is possible, but I'm trying to monitor the
> serial line for any input AND poll a handfull of pushbuttons
> simultaneoulsly. I have some code functions that doesn't work very
> well. If I pound on the pushbuttons I can get them to show up half
> of the time in that small window of opportunity they have to be
> recognized.
> I really don't want a hardware solution to this because I suck at
> electronics. However if there was some really easy way when I
press
> a pushbutton that it would stay in that state for a second or two
my
> routine would catch it. I was looking up RS Latches, but got
> horribly confused.
> The relevant code I have follows:
> WaitForCommand:
> 'First check for inputs from the computer
> Mode = 0
> SERIN RxD,Baud96,2000,ReadButtons,[noparse][[/noparse]WAIT ("?"), Mode,OutputID]
> 'waits for a ? to signal start then reads Mode, and OutputID
> '# to change
> IF Mode = "T" THEN ToggleIt 'Toggle the Output
> IF Mode = "N" THEN TurnOn 'Turn On the Output
> IF Mode = "O" THEN TurnOff 'Turn Off the Output
> IF Mode = "S" Then StateOfButtons 'Return State
> GOTO ReadButtons 'If no inputs from serial, check buttons
> 'connected to the Stamp
> ReadButtons:
> BUTTON 6,0,255,10,buttonData0,1,Button0
> BUTTON 7,0,255,10,buttonData1,1,Button1
> BUTTON 8,0,255,10,buttonData2,1,Button2
> BUTTON 9,0,255,10,buttonData3,1,Button3
> BUTTON 10,0,255,10,buttonData4,1,Button4
> BUTTON 11,0,255,10,buttonData5,1,Button5
> BUTTON 12,0,255,10,buttonData6,1,Button6
> BUTTON 13,0,255,10,buttonData7,1,Button7
> SEROUT Txd,Baud96,[noparse][[/noparse]"Nothing"] 'just for debugging
> GOTO WaitForCommand
> Button0:
> --do something because button 0 was pressed
> GOTO WaitForCommand
> THANKS IF YOU CAN HELP!
Lee Harker
> recognized.
press
my
> horribly confused.
> WaitForCommand:
> Mode = 0
> '# to change
> ReadButtons:
> GOTO WaitForCommand
> Button0:
> GOTO WaitForCommand
