How do I poll for serial input AND check for button changes at the same time?
I don't know if this is possible, but I'm trying to monitor the
serial line for any input AND poll a handfull of pushbuttons
simultaneoulsly. I have some code functions that doesn't work very
well. If I pound on the pushbuttons I can get them to show up half
of the time in that small window of opportunity they have to be
recognized.
I really don't want a hardware solution to this because I suck at
electronics. However if there was some really easy way when I press
a pushbutton that it would stay in that state for a second or two my
routine would catch it. I was looking up RS Latches, but got
horribly confused.
The relevant code I have follows:
WaitForCommand:
'First check for inputs from the computer
Mode = 0
SERIN RxD,Baud96,2000,ReadButtons,[noparse][[/noparse]WAIT ("?"), Mode,OutputID]
'waits for a ? to signal start then reads Mode, and OutputID
'# to change
IF Mode = "T" THEN ToggleIt 'Toggle the Output
IF Mode = "N" THEN TurnOn 'Turn On the Output
IF Mode = "O" THEN TurnOff 'Turn Off the Output
IF Mode = "S" Then StateOfButtons 'Return State
GOTO ReadButtons 'If no inputs from serial, check buttons
'connected to the Stamp
ReadButtons:
BUTTON 6,0,255,10,buttonData0,1,Button0
BUTTON 7,0,255,10,buttonData1,1,Button1
BUTTON 8,0,255,10,buttonData2,1,Button2
BUTTON 9,0,255,10,buttonData3,1,Button3
BUTTON 10,0,255,10,buttonData4,1,Button4
BUTTON 11,0,255,10,buttonData5,1,Button5
BUTTON 12,0,255,10,buttonData6,1,Button6
BUTTON 13,0,255,10,buttonData7,1,Button7
SEROUT Txd,Baud96,[noparse][[/noparse]"Nothing"] 'just for debugging
GOTO WaitForCommand
Button0:
--do something because button 0 was pressed
GOTO WaitForCommand
THANKS IF YOU CAN HELP!
recognized.
horribly confused.
WaitForCommand:
Mode = 0
'# to change
ReadButtons:
GOTO WaitForCommand
Button0:
GOTO WaitForCommand
is overkill for what you are trying to do.
Just read the state of all the buttons at once. This would be a
little easier if you had all of the 8 buttons on one port, say p8 to
p15, instead of p6 to p13. If they are all on one port then do this:
buttonState = inH ' reads all 8 buttons at once
buttonChange = buttonState ^ oldButtonState & oldButtonState
oldButtonState = buttonState
ON NCD buttonChange GOTO button0,button1,......,button7
That uses fewer variables but still debounces the buttons (using the
^ XOR logic between the old and new states), branching to to the
routine on the 1->0 transition.
As to the serial input, that is a harder nut to crack.
1) can you add handshaking, so that the computer will only send
the Stamp the data when the Stamp is ready? That would use the SERIN
RxD\flow syntax along with hardware handshaking on the PC. Or,
implement some kind of software Xon/Xoff handshaking.
2) make the timeout on the SERIN much shorter, say 0.1 second, but
include a WAIT modifier, before the data. The PC might have to
resend the data a couple of times.
3) add a capacitor to ground on each of the button inputs. The
code would charge up the capacitors, and a button pressed would
discharge it. So the capacitor holds the record of the event, that a
button was pressed or not when the program is off reading the serial
port.
-- Tracy
>recognized.
>horribly confused.
>WaitForCommand:
> Mode = 0
> '# to change
>ReadButtons:
>GOTO WaitForCommand
>Button0:
>GOTO WaitForCommand
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
