Sumo won''t turn and moves slowly
Hello Gregg and Jon,
Thanx for the info. As I am new in BASIC Stamp, I've
been searching for documents on how to program a
SumoBot and I've downloaded the SumoBot Manual in
Parallax's page and read through the document. I
started out with Experiment #2: SumoBot Locomotion.
Refering to page 12, I loaded the example program
given which will test the SumoBot's motors. I was
hoping to see a correct output but the robot went the
way i mentioned earlier.
I noticed that the SumoBot in the Parallax's page is
different from mine. Mine has 4 wheels and an on-off
power switch instead of a three-position power switch.
Can I still refer the manual? I would appreciate some
guidance. [noparse]:)[/noparse]
Thanx!
--- Gregg C Levine <hansolofalcon@w...>
wrote:
> Hello from Gregg C. Levine
> Very astute of you, Jon.
> But as you might have noticed, I mentioned that
> there are three
> different kinds of PWM output, one is indeed for
> servomechanisms, such
> as the ones worn by the robot, and the next one is
> for the DC motor
> drive systems, which is indeed not used here, and
> the third is the
> rarely used power supply systems.
> Without seeing the code being used, I suspected at
> first that the
> fault lay within the construction of the PWM
> statements. I now believe
> my earlier belief to be an accurate one, in view of
> your earlier
> statements. However, to confirm this analysis what
> we need to see is
> the complete code. I suggest that it should be
> posted.
> Gregg C Levine hansolofalcon@w...
> "The Force will be with you...Always." Obi-Wan
> Kenobi
> "Use the Force, Luke."· Obi-Wan Kenobi
> > From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zoH3jJaWpC1P7Rom8j7Ka_RbcgZueHOv72Hp1ebGm8PRPSE7Pt0yR-_w9UR0KhDfCeG3pvhcC7LKN25FXA46FQ]jwilliams@p...[/url
> > Sent: Sunday, April 11, 2004 1:47 PM
> > To: basicstamps@yahoogroups.com
> > Subject: RE: [noparse][[/noparse]basicstamps] re: Sumo won't turn and
> moves slowly
> > The SumoBot uses servos for locomotion so it
> doesn't use the kind of
> PWM signal
> > intended for DC motors.
> > -- Jon Williams
> > -- Applications Engineer, Parallax
> > -- Dallas Office
> > From: Eliza Yasmin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=v_5IKFdpbhmgrN9BP_evRVKmLzPlVGbkNwfnKRAbZGeawXVcGO2CtdW9iuXyF7K31__lIfh4tWJwLDGMVkXmZZo]eliza_yasmin@y...[/url
> > Sent: Sunday, April 11, 2004 12:02 PM
> moves slowly
> > Hello Gregg,
> > Looks like this topic is very new to me. My
> question
> > is related to the SumoBot. I'm new with the robot
> as
> > well. Can someone assist me on my problem? Besides
> > that, I'll also look up for PWM.
> > Thanx.
> > --- Gregg C Levine
> > wrote:
> > > Hello from Gregg C Levine
> > > PWM - Pulse Width Modulation. It's used for DC
> motor
> > > drive systems.
> > > That includes servomechanisms. Some power
> supplies
> > > use it as well.
> > > Before we get into a semi-on-topic discussion
> here,
> > > as this only
> > > partly applies to the Stamps, I suggest you
> check
> > > this subject out via
> > > your public library.
> > > Kenobi
> > > > From: Eliza Yasmin
> > > > Sent: Sunday, April 11, 2004 12:15 PM
> > > > Subject: Re: [noparse][[/noparse]basicstamps] re: Sumo won't turn
> and
> > > moves slowly
> > > > Dear George,
> > > > I can't understand what u are saying. What is
> PWM?
> > > Can
> > > > u pls explain in details.
> > > > Thanx.
> > > > --- George Warner <geowar@a...> wrote:
> > > > > > I have porgrammed a SumoBot to move
> forward
> > > then
> > > > > turn right. The
> > > > > > problem is, the robot won't turn right as
> if
> > > the
> > > > > robot is heavy. But
> > > > > > when I lift the robot, one wheel stop then
> the
> > > > > other moves (I assumed
> > > > > > the robot is doing what it is told). What
> > > might
> > > > > cause this to happen?
> > > > > > I also have another problem. When the
> robot
> > > moves
> > > > > forward, it would
> > > > > > stop sometimes. When I push a bit, the
> robot
> > > would
> > > > > moves again but
> > > > > > slowly. Is there something wrong with the
> > > coding?
> > > > > > Appreciate ur help. Thanx in advance.
> > > > > I've actually seen this happen when you're
> > > sending
> > > > > the PWM to the servo's
> > > > > too often (or not often enough).
> > > > > Enjoy,
> > > > > George Warner,
> > > > > Schizophrenic Optimization Scientists
> > > > > Apple Developer Technical Support (DTS)
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online by April 15th
http://taxes.yahoo.com/filing.html
Thanx!
> there are three
> for the DC motor
> the third is the
> first that the
> your earlier
> we need to see is
> posted.
> Kenobi
> moves slowly
> PWM signal
> > -- Jon Williams
> > -- Dallas Office
> moves slowly
> > Hello Gregg,
> question
> as
> > Thanx.
> > --- Gregg C Levine
> motor
> > > drive systems.
> supplies
> > > use it as well.
> here,
> > > as this only
> check
> > > Kenobi
> > > > From: Eliza Yasmin
> and
> > > moves slowly
> > > > Dear George,
> PWM?
> > > Can
> > > > Thanx.
> forward
> > > then
> > > > > turn right. The
> if
> > > the
> > > > > robot is heavy. But
> the
> > > might
> robot
> > > moves
> > > > > forward, it would
> robot
> > > would
> > > > > moves again but
> > > coding?
> > > sending
> > > > > Enjoy,
> > > > > George Warner,
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
