Faster PWMPAL
Is there a PWM controller available similar to
PWMPAL but with a much higher frequency?
Tom Fisher
Dallas,TX
Tom Fisher
Dallas,TX
> Thanks,
> Tom Fisher
> Dallas,TX
Higher input or output ?
Look at a Digital to Analogue (DAC) chip as an alternative.
I'm not sure why a higher frequency would be desired. the PWM is
generated in the software so has the limitation of the program in the
BS.
Then it's output is often filtered by an R/C into an op-amp, so a
single pwm output can have a steady state of some value for quite a
long time.
A rapid change may be more easily done by a DAC.
Just some thoughts.
Dave
> BS.
> long time.
> Just some thoughts.
> Dave
I'm trying to use the PWMPAL to drive a power FET(via a FET driver) to
control
an 8V 10amp brushed DC motor's speed. It works fine as long as
I keep the frequency above 10KHz but this only allows 6 speeds.
Tom Fisher
