Sumo won''t turn and moves slowly
The SumoBot uses servos for locomotion so it doesn't use the kind of PWM signal
intended for DC motors.
-- Jon Williams
-- Dallas Office
From: Eliza Yasmin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lRDqwPvY7UoEi0M0hkrWwxwOZ25YHSqxnk4HK7IdBTzxIgPMMYdP5BQvf-aMjm78HKeIri4PoXFKGEBz_w]eliza_yasmin@y...[/url
Sent: Sunday, April 11, 2004 12:02 PM
Subject: RE: [noparse][[/noparse]basicstamps] re: Sumo won't turn and moves slowly
Hello Gregg,
Looks like this topic is very new to me. My question
is related to the SumoBot. I'm new with the robot as
well. Can someone assist me on my problem? Besides
that, I'll also look up for PWM.
Thanx.
--- Gregg C Levine <hansolofalcon@w...>
wrote:
> Hello from Gregg C Levine
> PWM - Pulse Width Modulation. It's used for DC motor
> drive systems.
> That includes servomechanisms. Some power supplies
> use it as well.
> Before we get into a semi-on-topic discussion here,
> as this only
> partly applies to the Stamps, I suggest you check
> this subject out via
> your public library.
> Gregg C Levine hansolofalcon@w...
> "The Force will be with you...Always." Obi-Wan
> Kenobi
> "Use the Force, Luke."· Obi-Wan Kenobi
> > Sent: Sunday, April 11, 2004 12:15 PM
> > Subject: Re: [noparse][[/noparse]basicstamps] re: Sumo won't turn and
> moves slowly
> > Dear George,
> > I can't understand what u are saying. What is PWM?
> Can
> > u pls explain in details.
> > Thanx.
> > --- George Warner <geowar@a...> wrote:
> > > > I have porgrammed a SumoBot to move forward
> then
> > > turn right. The
> > > > problem is, the robot won't turn right as if
> the
> > > robot is heavy. But
> > > > when I lift the robot, one wheel stop then the
> > > other moves (I assumed
> > > > the robot is doing what it is told). What
> might
> > > cause this to happen?
> > > > I also have another problem. When the robot
> moves
> > > forward, it would
> > > > stop sometimes. When I push a bit, the robot
> would
> > > moves again but
> > > > slowly. Is there something wrong with the
> coding?
> > > > Appreciate ur help. Thanx in advance.
> > > I've actually seen this happen when you're
> sending
> > > the PWM to the servo's
> > > too often (or not often enough).
> > > Enjoy,
> > > George Warner,
> > > Schizophrenic Optimization Scientists
> > > Apple Developer Technical Support (DTS)
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online by April 15th http://taxes.yahoo.com/filing.html
from the same email address that you subscribed. Text in the Subject and Body
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
-- Jon Williams
-- Dallas Office
Hello Gregg,
Thanx.
> drive systems.
> use it as well.
> as this only
> Kenobi
> moves slowly
> > Dear George,
> Can
> > Thanx.
> then
> > > turn right. The
> the
> > > robot is heavy. But
> might
> moves
> > > forward, it would
> would
> > > moves again but
> coding?
> sending
> > > Enjoy,
> > > George Warner,
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
abuse@p....
