Sumo won''t turn and moves slowly
Hello from Gregg C Levine
PWM - Pulse Width Modulation. It's used for DC motor drive systems.
That includes servomechanisms. Some power supplies use it as well.
Before we get into a semi-on-topic discussion here, as this only
partly applies to the Stamps, I suggest you check this subject out via
your public library.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
> From: Eliza Yasmin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7vFJGohGeZxltPAsgRkWR7xgWeqjpqbkGza67QEPPEGydx3KSJw9kxDk7t5gCfOiBLyKcVn0fFgr5UqjxyyG]eliza_yasmin@y...[/url
> Sent: Sunday, April 11, 2004 12:15 PM
> Subject: Re: [noparse][[/noparse]basicstamps] re: Sumo won't turn and moves slowly
> Dear George,
> I can't understand what u are saying. What is PWM? Can
> u pls explain in details.
> Thanx.
> --- George Warner <geowar@a...> wrote:
> > > I have porgrammed a SumoBot to move forward then
> > turn right. The
> > > problem is, the robot won't turn right as if the
> > robot is heavy. But
> > > when I lift the robot, one wheel stop then the
> > other moves (I assumed
> > > the robot is doing what it is told). What might
> > cause this to happen?
> > > I also have another problem. When the robot moves
> > forward, it would
> > > stop sometimes. When I push a bit, the robot would
> > moves again but
> > > slowly. Is there something wrong with the coding?
> > > Appreciate ur help. Thanx in advance.
> > I've actually seen this happen when you're sending
> > the PWM to the servo's
> > too often (or not often enough).
> > Enjoy,
> > George Warner,
> > Schizophrenic Optimization Scientists
> > Apple Developer Technical Support (DTS)
> Dear George,
> Thanx.
> > turn right. The
> > robot is heavy. But
> > forward, it would
> > moves again but
> > Enjoy,
> > George Warner,
