"The Elements of PBASIC Style."
"PBASIC Style"? That's almost a contradiction of terms. ;-)
Although I do have a designer Tee shirt. Is that "Geek Style"? ;-)
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
Enjoy,
George Warner,
I think not.
George, even good old FPBASIC from Apple had that concept. Same with
Apple's Integer BASIC. There were, then, certain methods that every
program had to adhere to.
And now back to our regularly scheduled discussion on Basic Stamps,
and PBASIC.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
> From: George Warner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2hVK4nekhiz9qDeRawTGejz4ImEAAIXbhbgx2Q6F7oM9YSj2NNcuzZHUTovN5kIvnuANHAHzmEo]geowar@a...[/url
> Sent: Saturday, April 10, 2004 12:06 PM
> Subject: [noparse][[/noparse]basicstamps] "The Elements of PBASIC Style."
> Enjoy,
> George Warner,
become wildly successful (look how many companies make [noparse][[/noparse]almost]
PBASIC-compatible products).
The problem, in my opinion, is that many coders seem to think that
neatness counts for nothing. I know because I get a lot of code sent to
me for "fixing" and most of the problem has to do more with formatting
than anything else (most coders can't see their own errors through the
sloppiness of their code). With a little planning and neatness when
coding, most bugs can be prevented or more easily eliminated.
Okay, I'll get off my soapbox now ... but I will fervently hold onto the
opinion that most program bugs can be prevented by adopting and/or
adjusting the strategies in that document.
-- Jon Williams
-- Dallas Office
From: George Warner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5pNuLU47qJaSlh4ZCtZ9kk8wjN3Gg1FxATMsalBQa6zPKQscBd4V-FPP5JQuZthTRegs36lmEQ]geowar@a...[/url
Sent: Saturday, April 10, 2004 11:06 AM
Enjoy,
George Warner,
and easy to document. The new IDE helps with capitalization and
syntax coloring.
In the context of multibank programming and PBASIC 2.5, I have found
that my programming style for the Stamp has changed a lot in the past
year or so. On one hand, it used to be with the single bank BS2 that
I had to be frugal with every bit, parsimonious to the nth degree
with every feature of the program. Use E.g., PAUSE 128 instead of
PAUSE 100, just to save a couple of bits, or make a prompt 2 letters
instead of 5, because there was only one byte left before the dreaded
"out of eeprom" message.
With the luxury of multiple banks, that is no longer much of a
concern, so long as each group of "tasks" is broken down to a size
manageable in one bank. And the new structures in PBASIC 2.5 can be
applied (and more easily documented) even though the program will end
up larger in terms of code size compared to a program painstakingly
pared down for minimum size (but not as transparent).
-- Tracy
>No so! PBASIC is a very elegant language and for that reason it has
>-- Jon Williams
>-- Dallas Office
>From: George Warner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IuCR0T7S1ah6zes371v1TYQJoLRlOAK6Xr-3P6EUKCBQu5RDitu_oxt_jzkQvRzFXvj8qzfx-eE]geowar@a...[/url
>Enjoy,
>George Warner,
Whoa, let's talk about that. Is this because 128 is a power of 2?
Paul
>Paul
Hi Paul,
Yes, the Stamp internally stores the powers of 2 in a very compact form.
-- Tracy
