pic16f877 is the same as stamp 2sx ???
Hello
1. Does pic16f877 is the same as stamp 2sx , one memory of slot be
limited to 2k and then use "run" jump to another slot ??? (if use
picbasic pro compiler)
2. why is bs2sx's one memory of slot be limited to 2k ??? it
seems too small.
3. if I use many "gosub" "return" and program is bigger than
2k ,how should I do?? ( I think "run" can not be used)
(I bought bs2sx because I thought it has really 16k memory of
program)
thanks in advance.
sincerely
seems too small.
program)
thanks in advance.
sincerely
-- right or wrong -- to maintain that internal architecture when
designing newer versions of the BS2 family (to allow forward and
backward compatibility of most programs). In most cases, you WON'T run
past the 2K limit if you are careful in your coding (I've only ever done
it once in 10 years of using BASIC Stamps, and I've written some fairly
complicated programs that include a commerical product).
When you do need more program space, there are strategies that let you
use the other program banks for this. Try this:
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv87.pdf
-- Jon Williams
-- Dallas Office
From: john [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WXU1RabI9hz1Pn-8nkw2KlNo7E4bGqIZAKByWr4wANAbZCJF7s4EtPpUO6mA582Ad_p-M-YHMIKcLmewDm3LdOvU]w3102008@m...[/url
Sent: Saturday, April 10, 2004 5:30 AM
Subject: [noparse][[/noparse]basicstamps] pic16f877 is the same as stamp 2sx ???
Hello
seems too small.
program)
thanks in advance.
sincerely
