Serial interface hyperterminal help again
hey guys
THANKS
IT HELPED
Now im trying to use a pause in there
If no action is taken from the serial then goto
no action found
''{$STAMP BS2}
'{$PBASIC 2.5}
y VAR Byte
x VAR Byte
Main:
SERIN 16,16468,2000 [noparse][[/noparse]dec x]
TOGGLE x
'DEBUGIN x
y=50
'y = y & $0F * 10
IF x<>50 THEN GOTO wrong
'x = x & $0F
DEBUG ? x, CR
IF x=y THEN GOTO new
new:
DEBUG "right anwser",CR
DEBUG "in decemial it is ", BIN x,CR
GOTO done
wrong:
DEBUG "wrong anwser", CR
GOTO main
done:
DEBUG "all done", CR
STOP
BUT no matter what i hit on the keyboard it doesnt read it in AT ALL
Is there another way to justify this with a different statement by a pause or
another way to put a serin statement in there so it will read ?
PS I got this serin from the stamp book with modifications
THanks
please write back asap
kg_mini1098@y...
Al Williams <alw@a...> wrote:
If I recall, sending a Control+L (decimal 12) will clear HyperTerminal's
screen.
Al Williams
AWC
* Stamp Prototyping Board
http://www.awce.com/asp3.htm
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9hpbLHkDa6IWpKMe-u6ARIkqIkADsWlURoYcthaDRymXIjPGwczJuxjpMv4fPtn3Ed4zafuYUg]Newzed@a...[/url
Sent: Friday, April 09, 2004 12:25 PM
Subject: Re: [noparse][[/noparse]basicstamps] SERIAL INTERFACE HYPERTERMINAL
In a message dated 4/9/2004 1:22:05 PM Eastern Daylight Time,
jwilliams@p... writes:
> The easiest approach is to use DEBUG to send information to
> Hyperterminal, and DEBUGIN to receive it. If you do this, set
> HyperTerminal to 9600 baud, N81. It's easy, BASIC Stamp users do this
> all the time.
One thing about Hyperterminal - it does not recognize the "cls" command.
You
can not clear the screen - data just keeps scrolling forever. If you have a
problem let me know. I can send you a Hyper file designed for use with the
Stamp.
Sid Weaver
W4EKQ
Port Richey, FL
Yahoo! Groups Links
from the same email address that you subscribed. Text in the Subject and Body of
Yahoo! Groups Links
Thank you very much
Karen Ginsberg
kg_mini1098@y...
Do you Yahoo!?
Yahoo! Mail - More reliable, more storage, less spam
THANKS
IT HELPED
no action found
''{$STAMP BS2}
'{$PBASIC 2.5}
y VAR Byte
x VAR Byte
Main:
TOGGLE x
'DEBUGIN x
y=50
'y = y & $0F * 10
'x = x & $0F
DEBUG ? x, CR
new:
GOTO done
wrong:
GOTO main
done:
STOP
THanks
kg_mini1098@y...
screen.
Al Williams
AWC
> all the time.
You
Stamp.
Sid Weaver
W4EKQ
Port Richey, FL
Yahoo! Groups Links
Yahoo! Groups Links
Thank you very much
Karen Ginsberg
kg_mini1098@y...
Do you Yahoo!?
section).Also, I think the TOGGLE command is meant for the pin
numbers 0 - 15.
--- In basicstamps@yahoogroups.com, Karen Ginsberg <kg_mini1098@y...>
wrote:
> hey guys
> THANKS
> IT HELPED
> no action found
> ''{$STAMP BS2}
> '{$PBASIC 2.5}
> y VAR Byte
> x VAR Byte
> Main:
> TOGGLE x
> 'DEBUGIN x
> y=50
> 'y = y & $0F * 10
> 'x = x & $0F
> DEBUG ? x, CR
> new:
> GOTO done
> wrong:
> GOTO main
> done:
> STOP
a pause or another way to put a serin statement in there so it will
read ?
> THanks
> kg_mini1098@y...
HyperTerminal's
> screen.
> Regards,
> Al Williams
> AWC
> From: Newzed@a... [noparse][[/noparse]mailto:Newzed@a...]
this
> > all the time.
command.
> You
you have a
with the
> Stamp.
> Sid Weaver
> W4EKQ
> Port Richey, FL
Subject and
> Yahoo! Groups Links
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> Thank you very much
> Karen Ginsberg
> kg_mini1098@y...
> Do you Yahoo!?
bet you have hardware handshaking on and since you are not supplying
handshaking, Hyperterminal is dutifully not sending what you type because it
perceives that the Stamp is not ready.
By the way, the program is a bit baroque, but the free terminal at
http://realterm.sourceforge.net has several useful features for debugging
stuff.
Al Williams
AWC
*Easy RS232 Prototyping
http://www.awce.com/rs1.htm
From: Karen Ginsberg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AzxLS_nHceGeg1CV186LtAMU3687Q6psWhy1FC9c-MQU8sTTfQYmwWA1kPwZ-IAZBr9897W-rt8k9zyTDG9-rA]kg_mini1098@y...[/url
Sent: Saturday, April 10, 2004 1:45 AM
Subject: RE: [noparse][[/noparse]basicstamps] SERIAL INTERFACE HYPERTERMINAL HELP AGAIN
hey guys
THANKS
IT HELPED
no action found
''{$STAMP BS2}
'{$PBASIC 2.5}
y VAR Byte
x VAR Byte
Main:
TOGGLE x
'DEBUGIN x
y=50
'y = y & $0F * 10
'x = x & $0F
DEBUG ? x, CR
new:
GOTO done
wrong:
GOTO main
done:
STOP
BUT no matter what i hit on the keyboard it doesnt read it in AT ALL Is
THanks
kg_mini1098@y...
screen.
Al Williams
AWC
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GtHYyAyNk4wTW_CevU5zA30IQkhrUURNUGh9Q8117y8qv0R_-EgFKzD_2hdWrV7Hg5gteo9js3KS]Newzed@a...[/url
> all the time.
One thing about Hyperterminal - it does not recognize the "cls" command. You
Stamp.
Sid Weaver
W4EKQ
Port Richey, FL
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
Yahoo! Groups Links
Yahoo! Groups Links
Thank you very much
Karen Ginsberg
kg_mini1098@y...
Do you Yahoo!?
Yahoo! Groups Links
SERIN 16, 16468, 2000, No_Action, [noparse][[/noparse]DEC x]
With respect, your coding style is a bit sloppy and that will ultimately
get in the way as your programs get bigger. Let me suggest you read our
guide, "The Elements of PBASIC Style." It will give you ideas that will
help you write programs that are easier to understand and debug.
-- Jon Williams
-- Dallas Office
From: Karen Ginsberg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZVzfWgglnT7KupNwvDloh9-wtSrAVn8ZT5jglkVu3fRW_nuKBCgYM6YegwL6SUY6KLA4s2XmHvOlU94WdEA]kg_mini1098@y...[/url
hey guys
THANKS
IT HELPED
no action found
''{$STAMP BS2}
'{$PBASIC 2.5}
y VAR Byte
x VAR Byte
Main:
TOGGLE x
'DEBUGIN x
y=50
'y = y & $0F * 10
'x = x & $0F
DEBUG ? x, CR
new:
GOTO done
wrong:
GOTO main
done:
STOP
or another way to put a serin statement in there so it will read ?
THanks
kg_mini1098@y...
