BS2p input syntax
Hello everyone,
I have several inputs to a BS2p that are either on or off and wanted
to declare the inputs like this:
remotealarm var bit
motiondetect var bit
doorsensor var bit
question is, what methods are available to assign those to input
pins P0, P1, P2 ?
Is: remotealarm Pin5 one of the ways?
then following that I would need a DIR5 0 since it is an
input.
also need an example of an output bit that has a variable name and a
dedicated Pin.
I have not found any related examples except ones that are too simple
and others that are more involved than I need.
thanks for your help
Bruce
remotealarm var bit
doorsensor var bit
pins P0, P1, P2 ?
input.
dedicated Pin.
Bruce
your coding will become easy because the compiler can tell if you want
to use the declared pin as an input (look at the INS register bit) or an
output (set the OUTS register bit).
Like this:
RemoteAlarm PIN 5
MotionDetect PIN 6
DoorSensor PIN 7
IsON CON 1
IsOFF CON 0
So if you write this:
IF (RemoteAlarm = IsON) THEN
' do something
ENDIF
It is the same as writing
IF (IN5 = 1) THEN
' do something
ENDIF
By using the PIN declaration your code will be easier to read and debug,
and you'll be able to adjust the circuit with one edit (PIN declaration
line) versus all the places in your program that might examine that pin.
-- Jon Williams
-- Dallas Office
From: etech500 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=juOYbJ3OD_wChC2ujDxXQIjBGn0VC_Ck0WZlyy8t-_MEkmHlfDKTu8sndqcx1tIZM6rxujBBjqgraZQ]bmwbruce@a...[/url
Sent: Saturday, April 10, 2004 1:09 AM
Subject: [noparse][[/noparse]basicstamps] BS2p input syntax
Hello everyone,
remotealarm var bit
doorsensor var bit
pins P0, P1, P2 ?
input.
dedicated Pin.
Bruce
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
If you want further explanation of how the PIN typing works, the
following URL may either resolve confusion (or add too it!)
http://www.emesystems.com/BS2pbasic25.htm#PIN_examples
Most of the time, the PIN type will do exactly what you want. But
there are "tricky" uses where you need to understand the underlying
actions.
-- Tracy
>Use the PIN type function (you must declare $PBASIC 2.5 for this) and
>Like this:
>RemoteAlarm PIN 5
>MotionDetect PIN 6
>DoorSensor PIN 7
>IsON CON 1
>IsOFF CON 0
> ' do something
> ENDIF
> IF (IN5 = 1) THEN
> ' do something
> ENDIF
>-- Jon Williams
>-- Dallas Office
>From: etech500 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xaP4TgyaLlF0DwRjWn7goUUwTrHsisYdYuDkOXpQ44ArBCWifcmVjyR_8aoHVYthH3U0rQ0wig]bmwbruce@a...[/url
>Hello everyone,
>remotealarm var bit
>doorsensor var bit
>pins P0, P1, P2 ?
>input.
>dedicated Pin.
>Bruce
> Hello everyone,
> or off and wanted
> remotealarm var bit
> doorsensor var bit
Hey Bruce,
Looks like you're building some sort of Alarm
System. We've designed a few prototype Alarm Systems
with the BS2, and are currently working on an advanced
model using the BS2P40.
> those to input
> pins P0, P1, P2 ?
> since it is an
> input.
remotealarm pin 5
This would work. As for the DIR5 0, well you can set
up the DIRS for all pins with one command during the
Initialization in your code. That's what I do.
DIRS %1110001110001110 as an example.
Hope this helps!
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online by April 15th
http://taxes.yahoo.com/filing.html
