Serial interface hyperterminal
hi guys
how can you read a basic stamp serial interface using the
hyperterminal? which pins exactly do you use to read in from the
computer? thanks
kg_mini1098@y...
computer? thanks
kg_mini1098@y...
Hyperterminal, and DEBUGIN to receive it. If you do this, set
HyperTerminal to 9600 baud, N81. It's easy, BASIC Stamp users do this
all the time.
-- Jon Williams
-- Dallas Office
From: kg_mini1098 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cqK5vqsuoxNxNzqA9ZOGQGuBsTqqXhoN_uslKdmUEmV6Zu23cS8XDlyf1mUpsVDVutBgJhOwTzDrM6E8H6o]kg_mini1098@y...[/url
Sent: Friday, April 09, 2004 10:29 AM
Subject: [noparse][[/noparse]basicstamps] SERIAL INTERFACE HYPERTERMINAL
hi guys
computer? thanks
kg_mini1098@y...
jwilliams@p... writes:
> The easiest approach is to use DEBUG to send information to
> all the time.
One thing about Hyperterminal - it does not recognize the "cls" command. You
can not clear the screen - data just keeps scrolling forever. If you have a
problem let me know. I can send you a Hyper file designed for use with the
Stamp.
Sid Weaver
W4EKQ
Port Richey, FL
Sid, can you send me a copy as well? Directly. I'm going to be going
down that path soon, and I don't want to repeat my mistakes.
Oh, and where is Port Richey located? I might know the area. (Not
well, but well enough.)
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
> From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pW0aw0Fn4zzNNk6cKd0Ztco-G_bk1dqnAb9btPla83uBCAHNjdTh7Nm80f93c8t_75g3rhQzMQ]Newzed@a...[/url
> Sent: Friday, April 09, 2004 1:25 PM
> Subject: Re: [noparse][[/noparse]basicstamps] SERIAL INTERFACE HYPERTERMINAL
> In a message dated 4/9/2004 1:22:05 PM Eastern Daylight Time,
this
> > all the time.
command. You
you have a
with the
> Stamp.
> Sid Weaver
> W4EKQ
> Port Richey, FL
screen.
Al Williams
AWC
* Stamp Prototyping Board
http://www.awce.com/asp3.htm
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Nyfj1ZSKkKfsqxqHF5BeVvloHnnAsfDPTAHCEDjm30F2-T9tacX9IHhJ_lhi1Bae5oX_fk3fFEGd]Newzed@a...[/url
Sent: Friday, April 09, 2004 12:25 PM
> all the time.
You
Stamp.
Sid Weaver
W4EKQ
Port Richey, FL
Yahoo! Groups Links
alw@a... writes:
> If I recall, sending a Control+L (decimal 12) will clear HyperTerminal's
> screen.
You are correct. It does !! [noparse]:)[/noparse])
