Sumo won''t turn and moves slowly
> I have porgrammed a SumoBot to move forward then turn right. The
> problem is, the robot won't turn right as if the robot is heavy. But
> when I lift the robot, one wheel stop then the other moves (I assumed
> the robot is doing what it is told). What might cause this to happen?
> I also have another problem. When the robot moves forward, it would
> stop sometimes. When I push a bit, the robot would moves again but
> slowly. Is there something wrong with the coding?
> Appreciate ur help. Thanx in advance.
I've actually seen this happen when you're sending the PWM to the servo's
too often (or not often enough).
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
Enjoy,
George Warner,
