Stampw.exe Command-Line Options
I need to be clear where I can input command_Line Options.
When I hit Start->Run
In the Run field, Is this where I type in like
Stampw.exe {/Com#}
Alan
Stampw.exe {/Com#}
Alan
by using the Windows version of the compiler and specifying the desired
com port in the Properties dialog. You can also embed the desired port
in your code using a directive like this:
' {$PORT COMx}
... where x is your com port number.
Keep in mind that you can also set your compiler to scan all attached
com ports for a BASIC Stamp (the setting is Auto).
-- Jon Williams
-- Dallas Office
From: alan4100 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YUpkvq10S3tGOdLNNwQuPrLYVqhI5LgwJBkTfpxowh3CBbf5nj_WTI4LzOnrJuv6Q_w9Ce7fuZASwA]alan4100@c...[/url
Sent: Thursday, April 08, 2004 3:00 PM
Subject: [noparse][[/noparse]basicstamps] Stampw.exe Command-Line Options
Stampw.exe {/Com#}
Alan
