Sumo won''t turn and moves slowly
Hi there,
I have porgrammed a SumoBot to move forward then turn right. The
problem is, the robot won't turn right as if the robot is heavy. But
when I lift the robot, one wheel stop then the other moves (I assumed
the robot is doing what it is told). What might cause this to happen?
I also have another problem. When the robot moves forward, it would
stop sometimes. When I push a bit, the robot would moves again but
slowly. Is there something wrong with the coding?
Appreciate ur help. Thanx in advance.
