Typo in button program
Hello from Gregg C Levine
Take a look at the phrase that describes how the person is supposed to
connect a button switch to the P0 pin. Shouldn't that "and" be an "an"
instead? Oh, I did figure out the program's meaning. And did get it to
work, it produced the expect results. The term "active-low pushbutton
circuit", was easy to figure out, and the help page explained it.
[noparse][[/noparse] Description
' Connect and active-low pushbutton circuit to pin P0 of the BS1.
When you
' press the BUTTON, the DEBUG screen will display an asterisk (*).
Feel
' free to modify the program to see the effects of your changes on the
way
' BUTTON responds.
' Try changing the Delay value (255) in BUTTON to see the effect of
its
' modes: 0 = No debounce; 1-254 = Varying delays before auto-repeat;
' 255 = No auto-repeat (one action per button press).
However the typo is also present in the help page example. Are those
resistors necessary?
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
When you
Feel
way
' BUTTON responds.
its
has been corrected.
-- Jon Williams
-- Dallas Office
From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MWe8_LNH0vxWE6_rLUVeaOEF-THD1c8tqurhUwy76K234_M45-hE4DLzviDnCSr4poX7k0HD21zQF1lkIx_Nn6yU2HuoxeGB]hansolofalcon@w...[/url
Sent: Wednesday, April 07, 2004 9:34 PM
Subject: [noparse][[/noparse]basicstamps] Typo in button program
Take a look at the phrase that describes how the person is supposed to connect a
button switch to the P0 pin. Shouldn't that "and" be an "an" instead? Oh, I did
figure out the program's meaning. And did get it to work, it produced the expect
results. The term "active-low pushbutton circuit", was easy to figure out, and
' Connect and active-low pushbutton circuit to pin P0 of the BS1. When you '
press the BUTTON, the DEBUG screen will display an asterisk (*). Feel ' free to
modify the program to see the effects of your changes on the way ' BUTTON
responds. ' ' Try changing the Delay value (255) in BUTTON to see the effect of
its ' modes: 0 = No debounce; 1-254 = Varying delays before auto-repeat; ' 255 =
However the typo is also present in the help page example. Are those resistors
necessary?
from the same email address that you subscribed. Text in the Subject and Body
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
