Line Tracker
Does anyone have a diagram for how to connect the Line Tracker ver
2.0 made by Lynxmotion to the breadboard of the Board of Education?
this unit work. Can anyone guide me to the right location?
Thanks Mark
From: Joe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tJ74QTDuCzQnEeVrJH4PNg_ShQuz7eNvPdmX5_kEJP4rDwBV-RV8Jg6sP_m8lKLI_8UvEefyldLRR4Sf]JTFryman@c...[/url
Sent: Thursday, April 08, 2004 3:27 AM
Subject: [noparse][[/noparse]basicstamps] Line Tracker
Yahoo! Groups Links
If not you can get it here
http://www.lynxmotion.com/images/data/tra-v5.pdf
They have a lot of pictures showing how they hook it up at
http://www.lynxmotion.com/Product.aspx?productID=57&CategoryID=8
It is pretty simple, you don't need a lot to get it going.
It has indicator LED's too.
For example, depending on whether the line is black or white, you get a
simple high or low (1 or 0) when it is over or not over the line.
The code examples for using it is in the User's manual.
From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J6DQ76wbChFtkFhOU37UikQb1UhA398_VZWtEL4uXgLpLiGXWyjIGoqMRxVqZN7hBFpVH0IKtI4mFF7NzQ]mdevine@s...[/url
Sent: Wednesday, April 07, 2004 8:55 PM
Subject: RE: [noparse][[/noparse]basicstamps] Line Tracker
I am also looking for a place where I can download the software to make
Thanks Mark
From: Joe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WxQ7fUyYuDAs-BcmyUlUhlBfQ6ZjaMuiATsrLL67yxQgtfp3HYHdbUFM3LCTXsMpvC3Nx6ajiqjlN69C]JTFryman@c...[/url
Yahoo! Groups Links
Yahoo! Groups Links
> Thanks Mark
Download the pdf @: <http://www.lynxmotion.com/images/data/tra-v5.pdf>
"Programming Examples" are on page 6.
Red = +5vdc
Black = Ground
Yellow = Left Sensor Output
Blue = Center Sensor Output
Orange = Right Sensor Output
So hook red to +5 volts, black to ground, yellow, blue & orange to three
(unused) input pins (the example code uses pins 5, 6 & 7).
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
