Math! analogue or digital temperature sensor ?
--- In basicstamps@yahoogroups.com, "Kristoffer M. Hain" <haink@k...>
wrote:
> First off, thanks for everyone's reply on my DIG problem...got that
working
> well. Now, what I'm trying to do is rather complex (for me!)
> I need my bs2p to crunch this:
> TEMP = ((2.294 + (255 - ADCVAL) * (1.5) / 255) - 2.294) / (0.01 /
1.8) - 40
> TEMP is going to be an output temperature, and it can be an integer
value,
> I'm not worried about 78.2 or something silly like that. 78 is
> fine. ADCVAL is a number from 0-255, coming from an ADC0831.
Is there
> a better way to do this? I'm using an LM335AZ Precision temp
sender with
> the ADC...which are both fairly common chips, and I have all the
code to
> SHIFTIN from the chip....just need to convert the 0-255 to a
useable
> temperature. I know the above formula will do what I want, because
I have
> that line in a VB program I wrote a while back that uses both of
those
> chips....
> Thanks!!
> Kris Hain
My first question is that if precision is not important, why use
analogue ?
LM70, 3 wire SPI serial will offer better resolution with more
simplicity.
Dave
Dave
working
1.8) - 40
value,
Is there
sender with
code to
useable
I have
those
> chips....
> Thanks!!
> Kris Hain
analogue ?
simplicity.
Dave
Dave
for standardization across the board on any projects I use that require
temperature. I know it's kinda overkill.....
>working
>1.8) - 40
>value,
>Is there
>sender with
>code to
>useable
>I have
>those
> > chips....
> > Thanks!!
> > Kris Hain
>analogue ?
>simplicity.
>Dave
>Dave
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
