Math!
First off, thanks for everyone's reply on my DIG problem...got that working
well. Now, what I'm trying to do is rather complex (for me!)
I need my bs2p to crunch this:
TEMP = ((2.294 + (255 - ADCVAL) * (1.5) / 255) - 2.294) / (0.01 / 1.8) - 40
TEMP is going to be an output temperature, and it can be an integer value,
I'm not worried about 78.2 or something silly like that. 78 is
fine. ADCVAL is a number from 0-255, coming from an ADC0831. Is there
a better way to do this? I'm using an LM335AZ Precision temp sender with
the ADC...which are both fairly common chips, and I have all the code to
SHIFTIN from the chip....just need to convert the 0-255 to a useable
temperature. I know the above formula will do what I want, because I have
that line in a VB program I wrote a while back that uses both of those
chips....
Thanks!!
Kris Hain
chips....
Thanks!!
Kris Hain
To get enough accuracy you will have to keep your numbers and the
intermediate results as high as possible, but not higher than 65,536.
In
your specific case you could try the following calculation:
Temp1=(255-ADCVAL)*150/255 ' times 100 for accuracy, 2.294 equals
out
Temp2= 180 ' inversion of the division: 1/(0.01/1.8)
And then:
TEMP= Temp1*Temp2/100-40
In fact this multiplies part of your calculation by 100 and inverts
the
division for Temp2. At the end the multplied part is devided by 100
again.
It should work this way.
Klaus
--- In basicstamps@yahoogroups.com, "Kristoffer M. Hain" <haink@k...>
working
1.8) - 40
value,
Is there
sender with
code to
useable
I have
those
> chips....
> Thanks!!
> Kris Hain
1.8) - 40
This formula looks odd to me. Did you intend to have the 1.5
parenthesized or did you intend something different?
Secondly, unless I'm missing something the formula looks like:
((2.294 + X) - 2.294) / Y - 40
What's the point of adding and then subtracting 2.294?
Lastly, it might make sense for you to do the operations with a scale
factor of 100 in order to avoid loosing precision with integer
arithmetic. Also, you need to pay close attention to the order of
the operations. Try to arrange things to force the multiplication
operations to be done before the division operations. However, you
also need to make sure that you don't overflow the maximum positive
value of an integer with a full scale input value. If this becomes a
problem, you can intersperse some division operations to avoid
overflow. Additionally, if performance is a consideration, you
should combine some of the operations. For example, X / (0.01 / 1.8)
can be replaced with X * 180. Look for similar simplifications.
working
1.8) - 40
value,
Is there
sender with
code to
useable
I have
those
> chips....
> Thanks!!
> Kris Hain
Start by simplifying the expression to the form, Y = S * X + I.
Is the formula you wrote done with standard precedence, or with the
left to right precedence of the Stamp?
For example, looking briefly at the formula with standard precedence,
the first 2.294 would cancel out with the second one. With standard
precedence the output range is TEMP = {-40 to +230} for an input of
ADCVAL={255 to 0}. Is that right?
-- Tracy
>chips....
>Thanks!!
>Kris Hain
I think this is what I need! I'll try it tonight!
Thank you!!!
>Hi Kris,
>In
>out
>And then:
>the
>again.
>Regards,
>Klaus
>working
>1.8) - 40
>value,
>Is there
>sender with
>code to
>useable
>I have
>those
> > chips....
> > Thanks!!
> > Kris Hain
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
You're right on the below. The original formula was cobbled
together from 2 different things....and I should have simplified it years
ago, but if it's not broke...
Thanks for your help!
>Hi Kris,
> -- Tracy
> >chips....
> >Thanks!!
> >Kris Hain
>Yahoo! Groups Links
> chips....
IIRC multiplication & division happens before addition & subtractions so:
TEMP = ((((255 - ADCVAL) * 1.5 / 255) + (2.294 - 2.294)) / (0.01 / 1.8)) -
40
2.294 - 2.294 == 0, 0.01 / 1.8 == 1/180.0 & 1.5 / 255 == 1 / 170 therefore:
TEMP = ((((255 - ADCVAL) / 170)) / (1 / 180)) - 40
dividing by 1/180 is the same a multiplying by 180:
TEMP = ((255 - ADCVAL) / 170 * 180) - 40
And 180 / 170 == 18/17 therefore:
TEMP = ((255 - ADCVAL) * 18 / 17) - 40
Checking both formulas with ADCVAL == 0 & == 255:
Original formula with ADCVAL == 0:
TEMP = ((2.294 + (255 - 0) * 1.5 / 255) - 2.294) / (0.01 / 1.8) - 40
TEMP = ((2.294 + (255) * 1.5 / 255) - 2.294) / (0.005555) - 40
TEMP = ((2.294 + 382.5 / 255) - 2.294) / 0.005555 - 40
TEMP = ((2.294 + 1.5) - 2.294) / 0.005555 - 40
TEMP = (3.794 - 2.294) / 0.005555 - 40
TEMP = 1.5 / 0.005555 - 40
TEMP = 270 - 40
TEMP = 230
Reduced formula with ADCVAL == 0:
TEMP = ((255 - 0) * 18 / 17) - 40
TEMP = (255 * 18 / 17) - 40
TEMP = (4590 / 17) - 40
TEMP = 270 - 40
TEMP = 230
Original formula with ADCVAL == 255:
TEMP = ((2.294 + (255 - 255) * (1.5) / 255) - 2.294) / (0.01 / 1.8) - 40
TEMP = ((2.294 + (0) * 1.5 / 255) - 2.294) / (0.005555) - 40
TEMP = ((2.294 + (0) - 2.294) / (0.005555) - 40
TEMP = (0) / (0.005555) - 40
TEMP = 0 - 40
TEMP = -40
Reduced formula with ADCVAL == 255:
TEMP = ((255 - 255) * 18 / 17) - 40
TEMP = (0 * 18 / 17) - 40
TEMP = (0) - 40
TEMP = -40
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
