Master/Slave
Hello All,
This is all in the dream stage...
I am looking to write a simple "controller" program for my BOE-BOT. I
have built a simple wander bot with the SR04 sonar. The idea is that it
would do it normal thing of wandering around and avoiding objects. But
on top of that, I wanted to write a simple command interface from the PC
where I could send the stamp simple instructions (such as "left",
"right", "stop", "avoid light", seek light", etc) which would
change/override its natural behavior. I don't want the stamp tethered
by serial cable. I'm thinking this could be done IR using a sort of
morse code. Is there a better way? Will IR work at all? Will it be
overly complicated?
I want to do the software myself, so I'm not looking for specific source
code to do this. I am looking for a code sample to do one way (pc to
stamp) IR communication.
Again, I haven't built or coded anything beyond a simple wandering
robot, so the "specs" are really wide open.
Any help would be appreciated,
Happy building...
overly complicated?
Happy building...
Dream on! ;-)
> Morse code. Is there a better way? Will IR work at all? Will it be
> overly complicated?
You can use one of the "standard" IR receiver cans to receive (serial) input
from a standard TV remote and change your stamps behavior based on the 0-9
keys (or fast-forward, rewind, etc.); You'll have to play a little to see
what your remote sends for each key. Also pay attention that some remotes
"auto repeat" keys that are held down where others don¹t.
There's lots of PeeCee programs to output most remote IR codes to control
TV's, VCR, DVD, etc. Or you could just use ASCII.
I kind of prefer the TV remote solution since I'm more of a desktop CPU guy
and don't own a portable. If the BOE-BOT wanders out of my office and loses
its IR connection I can grab the remote and "drive" it back. ;-)
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
Parallax Bluetooth, EmbeddedBlue Transceiver (eb500), for the
communications with the pc. The eb500 user manual on the Parallax web site
has the sample code that I used to get started.
http://www.parallax.com/dl/docs/prod/comm/eb500.pdf
_________________
Sent: Tuesday, April 06, 2004 12:20 PM
Subject: [noparse][[/noparse]basicstamps] Master/Slave
> Hello All,
> overly complicated?
> Happy building...
> Yahoo! Groups Links
