SV: [basicstamps] Re: LCD Distance from BS2...
Greetings!
It may be possible that 'current loop' Serial connections will do, too.
I know that Tandberg terminals we used at the office had them, and they
were connected through up to 75Meters of cabling, to the ND mainframe.
(Running either at 9600 or 19200)
And that was rather shoddy Cat3 cabling...
Later on, we also used 'terminal servers' which slotted into the network
cabinets.
These had 8 serial ports and could be connected to another terminal
server or a TCP port on a server by issuing a simple text command from a
terminal hanging on one of the serial ports.
(A CONNECT xxxxxx something command. The Terminal server was smart
enough to use a DNS server to translate from names to IP)
It was simple enough that most users could do it.
(for those who couldn't we programmed a 'speed key' on the terminal)
I wish we still had some of those to play with...
Trygve
Opprinnelig melding
Fra: Brian [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OG0QfSr09e7jrFqXGmJyVpJ2LjfL9swU0vABVQwegKVlNwhV65-ZOJ6Pgf0aFev0gUOIOLZ0ajY]n7qjb@m...[/url
Sendt: 6. april 2004 08:03
Til: basicstamps@yahoogroups.com
Emne: [noparse][[/noparse]basicstamps] Re: LCD Distance from BS2...
You might think about some short haul modems. In a previous life we
had several Intel minis, and would use Telebyte 92 modems to run from
the mini to the terminal. If I remember right, with the baud rate
set down far enough, you could several miles out of them over phone
wire.
I just looked on Ebay, and there are a pair of Black Box modems with
a starting bid of 12.99
Good luck,
Brian
--- In basicstamps@yahoogroups.com, "Tim and Jo" <dema@t...> wrote:
> Hi Jon,
> I thought about that, and I know that it would be a good solution,
but I'm
> trying to keep the cost down as much as possible for this project.
> Tim
> From: "Jon Williams" <jwilliams@p...>
> To: <basicstamps@yahoogroups.com>
> Sent: Monday, April 05, 2004 5:20 PM
> Subject: RE: [noparse][[/noparse]basicstamps] LCD Distance from BS2...
> > Thoughts? How about an RF connection?
> > -- Jon Williams
> > -- Applications Engineer, Parallax
> > -- Dallas Office
> > From: Timothy Medema [noparse][[/noparse]mailto:timm@c...]
> > Sent: Monday, April 05, 2004 1:43 PM
> > To: basicstamps@yahoogroups.com
> > Subject: [noparse][[/noparse]basicstamps] LCD Distance from BS2...
> > Hi Everyone,
> > Can anybody tell me how far a serial LCD can be from the Basic
Stamp 2
> > that's driving it, assuming you are using good quality cable?
I'd like
> > to
> > mount a 16x2 serial LCD (yep, it's a Scott Edwards) about 300
feet from
> > the
> > BS2 if possible. Any thoughts?
> > Thanks,
> > Tim
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
Subject and
> Body of the message will be ignored.
> > Yahoo! Groups Links
Yahoo! Groups Links
cabinets.
Trygve
Opprinnelig melding
wire.
Good luck,
Brian
> Hi Jon,
but I'm
> Tim
> > -- Jon Williams
> > -- Dallas Office
> > Hi Everyone,
Stamp 2
I'd like
> > to
feet from
> > the
> > Thanks,
> > Tim
Subject and
> > Yahoo! Groups Links
Yahoo! Groups Links
It never ceases to amaze me the varied ideas that come out when a question
is asked of this group. This is yet another promising approach to look
into. Thank you.
Tim
At 03:40 AM 4/6/2004, you wrote:
>Greetings!
>cabinets.
>Trygve
Opprinnelig melding
>Fra: Brian [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=to8PMCjkzaEoEY3YD3AsVJbHvZRNaE_lueTxfthXYfvtXAYxx5pnjh204REZVdqtoQO0wczMi2c]n7qjb@m...[/url
>wire.
>Good luck,
>Brian
> > Hi Jon,
>but I'm
> > Tim
> > > -- Jon Williams
> > > -- Dallas Office
> > > Hi Everyone,
>Stamp 2
>I'd like
> > > to
>feet from
> > > the
> > > Thanks,
> > > Tim
>Subject and
> > > Yahoo! Groups Links
>Yahoo! Groups Links
>from the same email address that you subscribed. Text in the Subject and
>Yahoo! Groups Links
