review the program
Hi Stampers, again, Please I need a help of any to review the following program
and let me know what is its problem. it suppose to rotate the servo by pulses
and disply 1 and then 2. it is close to the one in the exercise but it is not
working well:
'{$STAMP BS2}
' What's a Microcontroller - RotateBridgeUsingDebugTerminal.bs2
' Send messages to the BASIC Stamp to control a Bridge using
' the Debug Terminal and 7-Segments display location.
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
OUTH = %00000000 'outh initialized to
low.
DIRH = %11111111 'set P8-P15
DO
'main routine.
DO
DEBUG "Enter 1000 to rotate Bridge:", CR
DEBUGIN DEC duration
IF duration < 1000 THEN
DEBUG "You must type 1000 to rotate the BRIDGE", CR
PAUSE 1000
ENDIF
IF duration > 1000 THEN
DEBUG "You must typr 1000 to rotate the BRIDGE", CR
PAUSE 1000
ENDIF
LOOP UNTIL duration > 999 AND duration < 1001
DEBUG "BRIDGE is rotating...", CR
FOR counter = 1 TO pulses
PULSOUT 7, 1000
PAUSE 20
NEXT
DEBUG "BRIDGE IN FLOWER HALL (1)"
PAUSE 1000
GOSUB TURN1
DO
IF duration < 500 THEN
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
DEBUG "BRIDGE IN ROCK HALL (2)"
PAUSE 1000
GOSUB TURN2
LOOP
Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Thank You
Khaled Sherbini
IIT Chicago, IL USA
Ph.D. Architectural Student
312-217-3594
http://www.khaledsherbini.com
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway - Enter today
working well:
'{$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
low.
DO
'main routine.
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN1
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN2
LOOP
Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
sherbinik@y... writes:
> PULSOUT 7, 1000
You haven't set "pulses" equal to anything - it has no value other than 0.
Sid
every 20 mSec, to go to one extent (full left?).
It wants a 2 mS pulse (repeated every 20 to 50
mSec) to go to the other extent (full right?).
It wants 1.5 mSec to center.
PULSOUT in BS2 does 2 uSec counts, so you want
1000 for 2mSec, and 500 for 1 mSec. These are
proper in your code.
You MUST pre-set the pin as output, and LOW,
BEFORE you issue the PULSOUT. You can do
both with:
LOW 7
This might fix it...
--- In basicstamps@yahoogroups.com, Khalid Sherbini <sherbinik@y...>
following program and let me know what is its problem. it suppose to
rotate the servo by pulses and disply 1 and then 2. it is close to
the one in the exercise but it is not working well:
> '{$STAMP BS2}
> ' {$PBASIC 2.5}
> counter VAR Word
> pulses VAR Word
> duration VAR Word
to
> low.
> DO
> 'main routine.
> DO
> PAUSE 1000
> ENDIF
> PAUSE 1000
> ENDIF
> PULSOUT 7, 1000
> PAUSE 20
> NEXT
> PAUSE 1000
> GOSUB TURN1
> DO
> PAUSE 1000
> ENDIF
> PAUSE 1000
> ENDIF
> PULSOUT 7, 1000
> PAUSE 20
> NEXT
> PAUSE 1000
> GOSUB TURN2
> LOOP
> Subroutines
> TURN1:
> OUTH = %10000100 '1
> PAUSE 1000
> RETURN
> TURN2:
> OUTH = %11010011 '2
> PAUSE 1000
> RETURN
> Thank you all
> Thank You
> Khaled Sherbini
> IIT Chicago, IL USA
> 312-217-3594
> Do you Yahoo!?
I will let you know what is the result after trying your suggestions
Allan Lane <allan.lane@h...> wrote:
I believe the Servo wants a 1 mS pulse, repeated
both with:
LOW 7
> '{$STAMP BS2}
> ' {$PBASIC 2.5}
> counter VAR Word
> pulses VAR Word
> duration VAR Word
to
> low.
> DO
> 'main routine.
> DO
> PAUSE 1000
> ENDIF
> PAUSE 1000
> ENDIF
> PULSOUT 7, 1000
> PAUSE 20
> NEXT
> PAUSE 1000
> GOSUB TURN1
> DO
> PAUSE 1000
> ENDIF
> PAUSE 1000
> ENDIF
> PULSOUT 7, 1000
> PAUSE 20
> NEXT
> PAUSE 1000
> GOSUB TURN2
> LOOP
> Subroutines
> TURN1:
> OUTH = %10000100 '1
> PAUSE 1000
> RETURN
> TURN2:
> OUTH = %11010011 '2
> PAUSE 1000
> RETURN
> Thank you all
> Thank You
> Khaled Sherbini
> IIT Chicago, IL USA
> 312-217-3594
> Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
suspect that is the root of no motion of the servo problem.It probbably has a
value of zero. You can Some suggestions, work in the smallest pieces of code
you can test. Start with the servo motion.Get it moving the way you and then add
the debug interface. I normally write my first block of code and define most or
all of my variables. Save it as a separate program. Then once I have all the
blocks working on their own, I start pasting them together. That way I can
isolate problems much more easily.
working well:
'{$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
low.
DO
'main routine.
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN1
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN2
LOOP
Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
motion using PC.
PHILIP GAMBLIN <gremlin8650@y...> wrote:
I can't see where you declare a value for your word-sized variable pulses . I
value of zero. You can Some suggestions, work in the smallest pieces of code you
can test. Start with the servo motion.Get it moving the way you and then add the
debug interface. I normally write my first block of code and define most or all
of my variables. Save it as a separate program. Then once I have all the blocks
working on their own, I start pasting them together. That way I can isolate
working well:
'{$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
low.
DO
'main routine.
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN1
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN2
LOOP
Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
ports connect to pins 12, 13, 14 or 15. Your pulsout is directed to
pin 7. Maybe the servos aren't getting any signal at all? Hope this
helps. Good Luck
wrote:
> I'm using the Debug Terminal to enter the PULSES to I can control
the servo motion using PC.
pulses . I suspect that is the root of no motion of the servo
problem.It probbably has a value of zero. You can Some suggestions,
work in the smallest pieces of code you can test. Start with the
servo motion.Get it moving the way you and then add the debug
or all of my variables. Save it as a separate program. Then once I
have all the blocks working on their own, I start pasting them
together. That way I can isolate problems much more easily.
> '{$STAMP BS2}
> ' {$PBASIC 2.5}
> counter VAR Word
> pulses VAR Word
> duration VAR Word
> low.
> DO
> 'main routine.
> DO
> PAUSE 1000
> ENDIF
> PAUSE 1000
> ENDIF
> PULSOUT 7, 1000
> PAUSE 20
> NEXT
> PAUSE 1000
> GOSUB TURN1
> DO
> PAUSE 1000
> ENDIF
> PAUSE 1000
> ENDIF
> PULSOUT 7, 1000
> PAUSE 20
> NEXT
> PAUSE 1000
> GOSUB TURN2
> LOOP
> Subroutines
> TURN1:
> OUTH = %10000100 '1
> PAUSE 1000
> RETURN
> TURN2:
> OUTH = %11010011 '2
> PAUSE 1000
> RETURN
> Thank you all
> Thank You
> Khaled Sherbini
> IIT Chicago, IL USA
> 312-217-3594
> Do you Yahoo!?
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
> Do you Yahoo!?
> Yahoo! Groups Links
> Thank You
> Khaled Sherbini
> IIT Chicago, IL USA
> 312-217-3594
> Do you Yahoo!?
There is no value in pulses.
From the code you posted it looks like you are reading DEBUG input into
duration.
I suggest that if you modify the above FOR statment to
FOR counter =1 TO 100
your servo will move.
I'm using the Debug Terminal to enter the PULSES to I can control the servo
motion using PC.
working well:
'{$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
low.
DO
'main routine.
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN1
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN2
LOOP
Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
duration.
motion using PC.
working well:
'{$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
low.
DO
'main routine.
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN1
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN2
LOOP
Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
Thank You
Khaled Sherbini
IIT Chicago, IL USA
312-217-3594
Do you Yahoo!?
Yahoo! Groups Links
Do you Yahoo!?
