bs2 and motorized pots
Do you know anything about motorized pots and the BS2?
Are these pots essentially DC motors and controlled as such?
Jordan
Jordan
Yes.
Usually. A good example of a "motorized pot" is your typical hobby servo; a
DC motor turns the axle which is connected to a pot which provides a
feedback voltage to the motor controller which compares the pot's voltage to
a voltage from an input PWM and turns the motor until the two voltages
match.
I've used the servo electronics to drive motorized pots. This is much
simpler since I can then control everything from a single PWM signal.
Enjoy,
George Warner,
Schizophrenic Optimization Scientists
Apple Developer Technical Support (DTS)
