DS1307 and BS2
If I want to set the time on a DS1307 using my BS2pe I write:
Wr1307 CON %11010000
I2COUT SDA, Wr1307, 0, [noparse][[/noparse]secs, mins, hrs]
If I wanted to use my BS2, could I write:
sda pin 0
scl pin 1
shiftout sda, scl, wr1307, 0, msbfirst, [noparse][[/noparse]secs, mins, hrs]
and achieve the same result?
Sid
sda pin 0
scl pin 1
Sid
clocking data, receiving an acknowledge bit, and generating a "stop"
condition. It can be done with the BS2, but requires a little more code
and you'll have to send just one byte at a time.
For details on I2C interfacing with a BS2 (or BS2e or BS2sx) this
article will help:
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv85.pdf
As you'll see after you read the article, the BS2p and BS2pe I2C
functions are really quite nice as they handle a bit workload for us.
-- Jon Williams
-- Dallas Office
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lOYC3xYu-xbnaEFbz26ev6fSW6w3v72B6g2KV5DZswn6glF6qJgXPwvTrpphRRGCnKUNPw]Newzed@a...[/url
Sent: Sunday, April 04, 2004 9:12 AM
Subject: [noparse][[/noparse]basicstamps] DS1307 and BS2
sda pin 0
scl pin 1
Sid
that uses I2C. The device demo is the PCF8574A that is included on the
NX-1000-24/40 lab board. The program includes low-level I2C subroutines
that can be used with any device, and a couple high-level routines for
writing to and reading from the PCF8574A. With this code and the data
sheet for the PCF8574A you'll see that I2C on the BS2 isn't that tough
and opens up a whole lot of opportunities.
I'll post the code in the files section.
-- Jon Williams
-- Dallas Office
Sent: Sunday, April 04, 2004 12:23 PM
Subject: RE: [noparse][[/noparse]basicstamps] DS1307 and BS2
No. I2C has a specific protocol that includes a "start" condition,
article will help:
-- Jon Williams
-- Dallas Office
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=A8cauD-gG_ZcOFK3NYKj7a8vjWWzRJspbpxvvYZDQx4ZFZm8wK2xIgzC4i6YnsBASX08fvsR]Newzed@a...[/url
sda pin 0
scl pin 1
Sid
clock parameters to BCD before transmitting to the clock - correct?
Sid
Decimal to BCD is easy with the BASIC Stamp:
bcdVal = (decVal / 10 << 4) + (decVal // 10)
To get from BCD to decimal:
decVal = bcdVal.NIB1 * 10 + bcdVal.NIB0
-- Jon Williams
-- Dallas Office
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AMkamV5GTTx5W8GcSA0kteU35JOc0sKucHm4yG9qXTpib72IjfvqEWp0rgfdA34DA-DWGmRhwWes]Newzed@a...[/url
Sent: Monday, April 05, 2004 7:58 AM
When writing code for the BS2 and the DS1307, I still have to convert my
Sid
>Sid
Yes, packed BCD. Two BCD clock digits packed into each byte.
E.g., $45 is 45 seconds.
If you have seconds in decimal, you have to convert it to packed BCD
before you set the clock:
secondsBCD = (seconds / 10 * 16) + (seconds // 10)
or another way to do it:
secondsBCD.nib1=seconds/10
secondsBCD.nib0=seconds//10
-- Tracy
the DS1307.
The 8583 sends the address for seconds as "2". If I read the data sheet for
the 1307 correctly, the address of the seconds register is 00, minutes 01,
and so on. Since I can only send one byte at a time I would send 00, seconds,
01, minutes, and so on. Is this correct?
Sid
to a specific address. Here's a snippet from code adapted for the
PCF8583:
' Write i2cData to i2cReg
Write_Byte:
GOSUB I2C_Start
i2cWork = Wr8583 ' send device address
GOSUB I2C_TX_Byte
i2cWork = i2cReg ' send reg number
GOSUB I2C_TX_Byte
i2cWork = i2cData ' send data
GOSUB I2C_TX_Byte
GOSUB I2C_Stop
RETURN
Notice that two values are passed: i2cData holds the value, i2cReg is
the register to write to. To set the seconds for the PCF8583, one would
do this:
i2cReg = 2
i2cData = 15
GOSUB Write_Byte
This code will work for the DS1307 -- you need to change the Wr8583 to
Wr1307 (and change the value to match the 1307) and then use the correct
registers as they are different from the PCF8583.
-- Jon Williams
-- Dallas Office
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GoyVoKKPoqj3359o19w9-97dij2ZRgJGRYr9Aglre7qvqppxzPko9HRWlkNpjEr8dv5C3A]Newzed@a...[/url
Sent: Monday, April 05, 2004 12:58 PM
I am trying to convert the BS2 I2C code for the PCF8583 for operation
with
the DS1307.
sheet for
01,
seconds,
Sid
Yes, the time registers in the DS1307 start at zero with seconds.
But if you have the time variables arranged in an array, with
seconds, minutes, hours, day-of-week, day, month, year, you can send
all 7 bytes as a single command with this format on the BS2p or
BS2pe...
I2COUT 0,$D0,0,[noparse][[/noparse]STR seconds\7]
| | | 7 bytes
| | starting adrs
| slave ID
pin
Or you could lay it out like this....
I2COUT 0,$D0,0,[noparse][[/noparse]seconds,minutes,hours,....,year]
I realized you say this is for the BS2, without the I2C commands.
There is no need to restart and send the address each time. The 7
bytes can be send in succession ...
start, slaveID, zero address, 7 bytes, stop.
-- Tracy
>I am trying to convert the BS2 I2C code for the PCF8583 for operation with
>the DS1307.
>Sid
Trying to run an I2C DS1307 on a BS2. I get this far and it locks up:
I2C_Start: ' I2C start bit sequence
INPUT SDA
INPUT SCL
LOW SDA ' SDA -> low while SCL high
Clock_Hold:
debug "Holding", cr
if (Ins.LowBit(SCL) = 0) THEN Clock_Hold ' device ready?
RETURN
I stuck the debug in so I could tell where the program was hanging up - its
hanging up in the Clock_Hold routine.
SDA is Pin 0, SCL is Pin 1. Isn't "Ins.LowBit" the same as IN0?
Is this enough information?
Sid
Do you have the required pullup resistors on both sda and scl?
When the program executes the INPUT scl command, the clock line
should definitely by high.
I don't understand why you are using the array syntax for this simple
debug? Why don't you just use In1, instead of Ins.LOWBIT(scl)?
If you use the PBASIC 2.5 declarations,
sda PIN 0
scl PIN 1
then PBASIC will interpret all the commands as needed
INPUT scl ' turns it into an input
IF scl=0 THEN Clock_Hold ' reads it as an input
But the main thing is, there is no excuse for scl to be low at that
point unless something is amiss in the hardware, i.e. missing the
pullup.
-- Tracy
>I hope someone out there can help.
> INPUT SDA
> INPUT SCL
>Clock_Hold:
>debug "Holding", cr
> RETURN
>Sid
write the current date and time and read it later for data collection
time stamping. I tried the line :
I2COUT SDA, Wr1307, 0, [noparse][[/noparse]$4f, $27, $56, $01, $0c, $04, 04]
with a modification of the program that parallax sends with the
DS1307, but cant seem to jump into the calendar. Any clues what I am
doing wrong?
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Sid,
simple
> sda PIN 0
> scl PIN 1
> pullup.
> -- Tracy
up:
sequence
> > INPUT SDA
> > INPUT SCL
SCL high
> >Clock_Hold:
> >debug "Holding", cr
> > RETURN
up - its
> >Sid
