serial comm styles ( was Re: parallax sales — Parallax Forums
edited 2004-04-04 18:15 in General Discussion
My favorite is I2C. It's easy to bit-bang with the BS2/BS2e/BS2sx and comes
built-in with the BS2p/pe, and there are a lot of really neat parts available
(really loving the MCP23016 at the moment).
I don't care for 1-Wire at all. Seems like a neat idea, but actual use of more
than one device on the same line is a major pain in the derri
    edited 2004-04-04 03:17
    > Okay, let's get back to fun stuff. Who has a question about
    programming
    > BASIC Stamps?
    > -- Jon Williams
    > -- Applications Engineer, Parallax
    > -- Dallas Office
    Ok,
    3 wire, 2 wire, 1 wire, iButton, etc.....
    Which is preferred and why ? I'm thinking BS2.
    It seems 3 wire is more common on many chips, but takes more lines.
    1 wire would be great because it uses a single pin....
    Comments ?
    Dave
    edited 2004-04-04 03:48
    I agree with Jon about I2C. It is really catching on now, as more
    companies license the protocol or whatever from Philips.
    On the Stamp, with the I2C commands you can use the modifiers like
    DEC and SPSTR. Everything with I2C is byte oriented.
    You cannot use the modifiers with the SHIFTIN SHIFTOUT commands.
    However, those commands can deal with unusual numbers of bits, like 3
    bits here or 12 bits there or any number from 1 to 16.
    There are a lot more 3-wire/SPI/microwire etc parts available than
    there are I2C.
    3-wire/SPI/microwire is a lot simpler protocol, because the third
    wire is a simple yes/no chip select, whereas with I2C all the address
    information has to be transmitted serially. But then you do need the
    extra hardware pins, one chip select for each device on the
    3-wire/SPI/microwire buss. With I2C, the two wires can handle a lot
    of devices.
    From an engineering standpoint, 3-wire protocols can be faster to
    transfer data than I2C, due to the additional addressing and
    handshaking in the I2C protocol. You hardly ever see I2C devices
    that can be clocked above 1 megahertz, but some SPI devices are rated
    to 10 or 20 megahertz or above. That doesn't make any difference to
    the BASIC Stamp though, which clocks either one at 10s of kiloherz.
    Both I2C and SPI/microwire are static logic, meaning that they can be
    clocked at any speed. That allows the BS2/BS2sx/BS2e, which don't
    have a built in I2C command to do it with bit-banging at about 100
    hz. The BS2p and BS2pe with the built in commands are just a lot
    faster, clocking I2C at 10s of khertz.
    One-wire, on the other hand is very picky about its timing. Timing
    has to happen within critical windows of 10 to 100 microseconds.
    That is why it can't be bit banged on the older Stamps.
    -- Tracy
    >and comes built-in with the BS2p/pe, and there are a lot of really
    >neat parts available (really loving the MCP23016 at the moment).
    >use of more than one device on the same line is a major pain in the
    >derri
    edited 2004-04-04 06:17
    Hello from Gregg C Levine
    Jon, can you elaborate on why the NSC version of the SPI devices work
    differently then the ones from Microchip? Or even Excel, assuming they
    are still in business. Currently I've got a surplus of the ones from
    NSC, but nothing from Microchip.
    Gregg C Levine hansolofalcon@w...
    "The Force will be with you...Always." Obi-Wan Kenobi
    "Use the Force, Luke."· Obi-Wan Kenobi
    > From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Fw1JSmQdmgnkaBJAqT5VmP4Cc3dItx7Bx4HZW8Aln6ig2vDZ6NaFjQoi7ZAiqsp3sBOkO5NHON-1dzGBor60Cg]jwilliams@p...[/url
    > Sent: Saturday, April 03, 2004 9:05 PM
    > Subject: RE: [noparse][[/noparse]basicstamps] serial comm styles ( was Re: parallax
    sales
    and comes built-
    > device on the same line is a major pain in the derrière (especially
    if you don't know
    > the serial numbers in advance). The only reason I wrote about the
    DS2760 in my
    > Nuts & Volts column was that it was the heart of a neat project
    (thermocouple
    > interface) and it was just as single device on the line. I'm fairly
    certain, however,
    > that will be my last 1-Wire project with the BASIC Stamp.
    > -- Jon Williams
    > -- Dallas Office
    > From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dVo1JDxkzRoHj662XmDHkwtoTlyloGiNMiT5COimYacBCugV3q5TOA20hrWCJBt-WEw5c8RnxTV45K2gRg]davemucha@j...[/url
    > Sent: Saturday, April 03, 2004 7:17 PM
    > Subject: [noparse][[/noparse]basicstamps] serial comm styles ( was Re: parallax sales
    > programming
    > > BASIC Stamps?
    > > -- Jon Williams
    > > -- Dallas Office
    > Ok,
    > Comments ?
    > Dave
    edited 2004-04-04 06:20
    I don't know.
    -- Jon Williams
    -- Dallas Office
    From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DVJLpXTG0SK3Q9BBa62AzhJxEWNYWt4fNXDVZJJdfB8HPr4Kn7wJB4jp2dS5YjYbnUw4RJRAFz70k7YtulA_T6-2Sxfkgg]hansolofalcon@w...[/url
    Sent: Saturday, April 03, 2004 11:18 PM
    Subject: RE: [noparse][[/noparse]basicstamps] serial comm styles ( was Re: parallax sales
    differently then the ones from Microchip? Or even Excel, assuming they are still
    in business. Currently I've got a surplus of the ones from NSC, but nothing from
    Microchip.
    > From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9WlTM66b8ilIz5Eq9ZbMRyQfYeY8YI7aKliyJ7NcgpueCtTOiyyqgIpukxNRQ10di1aEy95guV55KG9VwGXXrQ]jwilliams@p...[/url
    sales
    and comes built-
    if you don't know
    DS2760 in my
    (thermocouple
    certain, however,
    > -- Jon Williams
    > -- Dallas Office
    > From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FC3ybwMnjVDAC8SANIWmn6FNDnhxRDEjVkbaGyFBc8V1H7Zq4duTWmWKE-Vhldj77WKEEXjQqHY]davemucha@j...[/url
    > programming
    > > BASIC Stamps?
    > > -- Jon Williams
    > > -- Dallas Office
    > Ok,
    > Comments ?
    > Dave
    from the same email address that you subscribed. Text in the Subject and Body
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2004-04-04 14:48
    Hello (again) from Gregg C Levine
    You say, "> I don't know.", (comment from mail program included.) Do
    those comments from that original program look familiar to you? To
    anyone else? I think I have that number here, from NSC, I know I've
    got the others in that series. Those chips always struck me as odd.
    Now I know better, but I am still confused.
    ' Program: EEPROM.BAS
    ' This program demonstrates subroutines for storing data in a
    ' Microchip 93LC66 serial EEPROM. This program will not work
    ' with the National Semiconductor part with the same number.
    ' Its serial protocol is substantially different.
    The thing is, since the program ends in .BAS, it could be for any of
    the Stamps. Not just for the Stamp 1, but for the 2, and each of
    those.
    > From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nw7at36P4CbhhaK_q8OD41J70_LiF7UsrSOoQK25q5pOVESqZ5LX5gX7l7j_rO1rrMVi8zdznRz09ObI]jwilliams@p...[/url
    > Sent: Sunday, April 04, 2004 12:21 AM
    sales
    > I don't know.
    > -- Jon Williams
    > -- Dallas Office
    > From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7QDhBtnIv8tgwR5TN7L2_Jl76D8Za4hGGB8ozJzooWJmD8sJ7vz0mKRxr4oJsSENB6XIJlmDQm4Ar47L98-bBZ0Mcaxn]hansolofalcon@w...[/url
    sales
    work differently
    in business.
    Microchip.
    > sales
    > and comes built-
    actual
    (especially
    > if you don't know
    > DS2760 in my
    > (thermocouple
    fairly
    > certain, however,
    > > -- Jon Williams
    > > -- Dallas Office
    > > From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JXXYm0yeSnuEL0JhI-zMNdkl2XJS65A12gF11wanfGJci-TcY9qXDc0JCEbfktxvEHh8rIXKsaM7]davemucha@j...[/url
    > > programming
    > > > BASIC Stamps?
    > > > -- Jon Williams
    > > > -- Dallas Office
    > > Ok,
    lines.
    > > Comments ?
    > > Dave
    edited 2004-04-04 15:13
    >those.
    Gregg -
    Looking at the program per se and not just the name will give one a much better
    idea of which Basic Stamp that particular program is suited for. One simple cue
    is the use of the keyword SYMBOL. I.E. SYMBOL SW0 = pin0 . If you look at the
    Stamp PBASIC Manual in the Stamp I section, you will notice other unique
    keywords as well.
    As far as Microchip vs. National parts are concerned it may be as something as
    simple as timing, and the author wanted to warn any future users of this
    demonstration program that the supplier of the chip was important for that
    reason.
    Internal to the program, there would be no practical way (other than asking)
    which manufacturers part was installed.
    Bruce Bates
    edited 2004-04-04 16:41
    I agree with Jon. My favorite is I2C. Almost everything else is
    faster, but I2C is so dang simple.
    And 1-wire...I've never liked timing critical communication.
    edited 2004-04-04 17:35
    It looks like an older Parallax demo for the BS1 (.BS2 is used for the BS2
    family) -- probably written by Scott Edwards way back when. The best thing to
    do -- as I frequently suggest -- is download the data sheets for the parts in
    question.
    -- Jon Williams
    -- Dallas Office
    From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EJdXy9zDNEfQACY6d6fZR5OB3rf_AdWPHc9tkQuYC1WYdizHs66LQtMti5HMTn1ciS7rQFd9x9DNNoQOPvhycSI7OQnNtA]hansolofalcon@w...[/url
    Sent: Sunday, April 04, 2004 8:49 AM
    You say, "> I don't know.", (comment from mail program included.) Do those
    comments from that original program look familiar to you? To anyone else? I
    think I have that number here, from NSC, I know I've got the others in that
    series. Those chips always struck me as odd. Now I know better, but I am still
    confused.
    The thing is, since the program ends in .BAS, it could be for any of the Stamps.
    Not just for the Stamp 1, but for the 2, and each of those.
    > From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5UVevxX6t2dZLJC60jq4yPkXYv9sLj9N6H3C1dhCOHyzsRoycRy-9TFIM9pTA18VT90v2JSMi6OUJt4hVc8]jwilliams@p...[/url
    sales
    > I don't know.
    > -- Jon Williams
    > -- Dallas Office
    sales
    work differently
    in business.
    Microchip.
    > sales
    > and comes built-
    actual
    (especially
    > if you don't know
    > DS2760 in my
    > (thermocouple
    fairly
    > certain, however,
    > > -- Jon Williams
    > > -- Dallas Office
    > > From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vcTm_HnW-rKn09cv3rWXdcRs1XMEiSDY0lJI6eiK1mKXVrtBtoZ63Bo0EO17g3c92xOWdI5tfB0]davemucha@j...[/url
    > > programming
    > > > BASIC Stamps?
    > > > -- Jon Williams
    > > > -- Dallas Office
    > > Ok,
    lines.
    > > Comments ?
    > > Dave
    Yahoo! Groups Links
    abuse@p....
    I agree. In fact, when I first read the program, (This time.), I
    recognized the coding style, as that of his, especially since it
    didn't have someone's name in the comments, as most of us do, and yes,
    Jon, it did not look like one of yours.
    What I did do, is register on Microchip's site, for free samples, and
    site purchases of parts, and then selected for sampling, that part
    number, and the one on the Parallax site. When they get here, I'll see
    for myself, if the original author is right, and we should stick to
    only Microchip parts, when it comes to external memory, or it’s
    personal preferences of the author at work.
    Bruce suggested a comparison between code for a BS1, and the BS2.
    Which I might do, but since it came with the original download of the
    stuff for the BS1, that I bought originally, I'm also inclined to
    believe that you're right also.
    > From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QMZOU6nK6bvpbk2S6XQiU-RnMMnYLVqm50Sue0OcWF7r6fO0eAxiQkunIevNJQjWc8-jgmw2v2R6bLqHbCtg1g]jwilliams@p...[/url
    > Sent: Sunday, April 04, 2004 12:35 PM
    sales
    the BS2 family) --
    do -- as I
    question.
    > -- Jon Williams
    > -- Dallas Office
    > From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9FfXp_31sAulJLRtFNVeyDOQNkVLIE1ntaZ4qoHCGbkwuFywBkP0eff7nK8fmCDtX9HtGEypRxgE4PhKzPZl6GQCv0sc2mQR]hansolofalcon@w...[/url
    sales
    those
    else? I think I
    series. Those
    confused.
    the Stamps. Not
    > sales
    > > I don't know.
    > > -- Jon Williams
    > > -- Dallas Office
    > sales
    > work differently
    still
    > in business.
    from
    > Microchip.
    > > sales
    BS2/BS2e/BS2sx
    > > and comes built-
    > actual
    > (especially
    > > if you don't know
    the
    > > DS2760 in my
    > > (thermocouple
    > fairly
    > > certain, however,
    > > > -- Jon Williams
    > > > -- Dallas Office
    > > > From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=crkh_dhHYB-Zfj22KT7SnwH8WmdUx909MeenByXaGYCmw1rWSX6-K6iWnlF_HpthQCPuCTBCrxX6LQa5]davemucha@j...[/url
    sales
    > > > programming
    > > > > BASIC Stamps?
    > > > > -- Jon Williams
    > > > > -- Dallas Office
    > > > Ok,
    > lines.
    > > > Comments ?
    > > > Dave
