Protecting BS2 Inputs
I saw another BS2 byte the dust today. I believe this occurred because the
individual
connected five volts directly to the I/O pin.
I would like to permanently connect 1k resistors to each I/O as a means to
protect
them from accidental shorts to Vdd. Is there a reason not to do this? Are
there
circuits or sensors that will not operate if a 1k resistor is atached to the
pin?
Paul
individual
protect
there
pin?
Paul
To protect the stamp, the recommended value resistor to connect in series
with each I/O pin is 220 ohms.
ken
individual
protect
there
pin?
Paul
output low.
The reason not to add a 1K resistor in series with every pin is that you
may affect what the pin is doing for other functions. For our
student-oriented HomeWork board we put 220 ohm resistors in series with
each pin for protection. By doing this, we can eliminate the 220
normally used in RCTIME, and we can use 220 for LEDs (or bump back up to
470 if we're lighting a bunch of LEDs). 220 is enough to protect a pin
for an errant programming error (which is in fact the real killer of
microcontrollers ... and we've all done it).
We haven't found anything adversely affected by the 220 ohm resistor --
but that's not to say that there isn't some device or sensor out there
that won't like it.
-- Jon Williams
-- Dallas Office
From: verhap@o... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kLLoPgWZkG2k2RTaI_qitEYJkkQT5_5lRUXlwcyq3UF9dwZSXP6QZNWGwgdIpuUMXOPsFaUhb5DHJMwiDL47iq4a]verhap@o...[/url
Sent: Saturday, April 03, 2004 2:27 PM
Subject: [noparse][[/noparse]basicstamps] Protecting BS2 Inputs
the individual
to protect
Are there
the pin?
Paul
>because the individual
>means to protect
>this? Are there
>atached to the pin?
>Thanks,
>Paul
I use 330 ohms in my data loggers. When powered with 12 volts,
someone sometime is going to hook 12 volts directly to an input pin.
With the pin low and 330 ohms, the current is limited to less than 35
milliamps, which is within the ratings of the SX48 chip. With 220
ohms, the current could be 55 ma, which is pushing it. The inputs
are remarkably resilient, but it better to avoid the insults. The
question is, what insults are likely to occur in your particular
system? If it is a 28 volt system, then maybe the 1kohm resistors
would be a good call. If there is severe ESD threat, a network of
resistors and transorbs would be justified. But if everything is 9
volts or less, the 220 ohms are perfect.
Some solid state relays will not turn on reliably from 5 volts with a
1k series resistor. Better to go with 220 to 470.
There might be a situation where you need to provide a microsecond
pulse of high current, so you have to leave out the resistor. Say
you need to charge up the input capacitor of a big MOSFET, fast, so
that the MOSFET will turn on fast. Even though the MOSFET input
capacitor will draw a pulse of current, it will be so short that it
won't matter for the Stamp.
Reference data for single pin source and sink current...
***BS2/PIC16C57 at 5 volts Vdd, 25 degrees C...
short circuit source current: 40 milliamps
rated maximum source current: 20 milliamps
small signal source resistance: 75 ohms
short circuit sink current: 60 milliamps
rated maximum sink current: 25 milliamps
small signal sink resistance: 33 ohms
***BS2sx, e, p, pe using SX.. at 5 volts Vdd, 25 degrees C...
short circuit source current: 80 milliamps
rated maximum source current: 45 milliamps
small signal source resistance: 25 ohms
short circuit sink current: 130 milliamps
rated maximum sink current: 45 milliamps
small signal sink resistance: 12 ohms
Note that the short circuit currents are way more than they can
handle continuously. The above figures are directly from the PIC and
SX data sheets, and I have verified that they are pretty close to
reality for the SX chip.
If you connect a Stamp pin directly to a capacitor, and then, HIGH
it, the rate of charge will be at first the short circuit current,
and then, as the capacitor approaches full charge, the rate is
determined by the small signal source or sink resistance.
Note also that all the chips have limits on the total current to/from
any one 8 bit port.
-- Tracy
No problem as long as the electrical specs
(basing on parts datasheets) for both
the BS2 I/O and your sensors are met.
Just keep note that the resistors limits current.
And in ohms law, when your current change the voltage
also changes, and might be out of the component's electrical
requirement.
Bing
means to protect
this? Are there
atached to the pin?
> Thanks,
> Paul
