Rotate servo program
Hi Stampers
Can you chack the following program, it is to rotate a servo and disply 1 or 2;
it is close to one of the examples but not working well:
'{$STAMP BS2}
' What's a Microcontroller - RotateBridgeUsingDebugTerminal.bs2
' Send messages to the BASIC Stamp to control a Bridge using
' the Debug Terminal and 7-Segments display location.
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
OUTH = %00000000 'outh initialized to low.
DIRH = %11111111 'set P8-P15
DO
'main
routine.
DO
DEBUG "Enter 1000 to rotate Bridge:", CR
DEBUGIN DEC duration
IF duration < 1000 THEN
DEBUG "You must type 1000 to rotate the BRIDGE", CR
PAUSE 1000
ENDIF
IF duration > 1000 THEN
DEBUG "You must typr 1000 to rotate the BRIDGE", CR
PAUSE 1000
ENDIF
LOOP UNTIL duration > 999 AND duration < 1001
DEBUG "BRIDGE is rotating...", CR
FOR counter = 1 TO pulses
PULSOUT 7, 1000
PAUSE 20
NEXT
DEBUG "BRIDGE IN FLOWER HALL (1)"
PAUSE 1000
GOSUB TURN1
DO
IF duration < 500 THEN
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
DEBUG "BRIDGE IN ROCK HALL (2)"
PAUSE 1000
GOSUB TURN2
LOOP
' Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway - Enter today
'{$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulses VAR Word
duration VAR Word
DO
'main
routine.
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN1
DO
PAUSE 1000
ENDIF
PAUSE 1000
ENDIF
PULSOUT 7, 1000
PAUSE 20
NEXT
PAUSE 1000
GOSUB TURN2
LOOP
' Subroutines
TURN1:
OUTH = %10000100 '1
PAUSE 1000
RETURN
TURN2:
OUTH = %11010011 '2
PAUSE 1000
RETURN
Thank you all
Do you Yahoo!?
