pulses>>>> to Jonathan Peakall
Dear Jonathan Peakall,
my application is to measure the velocity of a real car with the
maxamimum accurity that stamp can do. also it should measure at least
100 mph and if it possible to calculate more speed it will be ok. i
think If we use the PULSIN command to see how long a pulse, the
problem may will be with the car lenght specialy if we use laser
sensor!!
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@p...> wrote:
> Daen,
> How to do what you want depends on what you are doing. Is it a real
car or a
> model, and how fast is it going? What level of accuracy do you
need? The
> Stamp doesn't have a timer, but you can count program loops and get
pretty
> good accuarcy.
> I made a velocity meter for my coilgun using a Stamp. I did it with
one
> sensor, and used the PULSIN command to see how long a pulse was
made as the
> projectile went through the gate. As the length of the projectile
is known,
> the speed can be calculated from the length of the pulse. Works
quite well
> for my application.
> Give us some more details of your application, and maybe we can be
of more
> help.
> Jonathan
> www.madlabs.info
> From: "daen78" <daen78@y...>
> To: <basicstamps@yahoogroups.com>
> Sent: Thursday, April 01, 2004 5:08 AM
> Subject: [noparse][[/noparse]basicstamps] pulses
> > I want to measure a speed of car...
> > I have 2 sensors! When the car cross the first sensor, i
> > receive
> > a pulse! When the car cross cross the second sensor, i receive
other
> > pulse!
> > I want to measure the lenght between pulses...does someone
> > have some suggestion? and what is the best IR sensor should i
use??
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
Subject and
> Body of the message will be ignored.
> > Yahoo! Groups Links
sensor!!
> Daen,
car or a
need? The
pretty
> good accuarcy.
one
made as the
is known,
quite well
> for my application.
of more
> help.
> Jonathan
> www.madlabs.info
> > receive
other
> > pulse!
use??
Subject and
> > Yahoo! Groups Links
what kind of car is this? is it manual or automatic transmission.
If it's automatic you can only get true speed measurements from the
drivetrain.
If it's manual, you could put a sensor on the CAM pulley (or whatever pulley
is external to the cam). You'll still need to know which gear you are in
(use switches?) and some calibration formulas to boot.
Only problem with the manual transmission is the time it takes you to
engage/disengage the clutch. As the motor will be reving and not all the
power will be on the drivetrain yet (clutch semi-slipping).
sb
Sent: Saturday, April 03, 2004 3:51 AM
Subject: [noparse][[/noparse]basicstamps] Re: pulses>>>> to Jonathan Peakall
> sensor!!
> > Daen,
> car or a
> need? The
> pretty
> > good accuarcy.
> one
> made as the
> is known,
> quite well
> > for my application.
> of more
> > help.
> > Jonathan
> > www.madlabs.info
> > > receive
> other
> > > pulse!
> use??
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
several times. Depending on accuracy and which stamp you have will dictate the
best
route to complete this project.
ken
--- smartdim@a... wrote:
> What kind of car is this and what acuracy do you
> want? I have done this
> you have will dictate the best
> ken
> car with the
> measure at least
> it will be ok.
> removed]
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
The Boat must float and all fish must take the bait sooner or later.
__________________________________
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway
http://promotions.yahoo.com/design_giveaway/
visual sensor. count the revolutions? I do not know,
I am merely offering an idea.
--- SB <steve.brady@r...> wrote:
> daen78,
> transmission.
> drivetrain.
> boot.
> semi-slipping).
> sb
> Peakall
> real car with the
> it will be ok. i
> long a pulse, the
> if we use laser
> > sensor!!
> Peakall"
> > > Daen,
> doing. Is it a real
> > car or a
> accuracy do you
> > need? The
> > pretty
> > > good accuarcy.
> > one
> long a pulse was
> > made as the
> of the projectile
> > is known,
> the pulse. Works
> > quite well
> > > for my application.
> and maybe we can be
> > of more
> > > help.
> > > Jonathan
> > > www.madlabs.info
> sensor, i
> > > > receive
> sensor, i receive
> > other
> > > > pulse!
> sensor should i
> > use??
> > Subject and
> > > > Yahoo! Groups Links
> > Yahoo! Groups Links
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
We still need a little more detail on your project. Can the device be in the
car, or do you want to drive it through a sensor?
If the sensor must be outside of the car: The PULSIN with a single photogate
probably won't work, because the PULSIN command time period is too short.
Unless you are going REALLY fast ;-). However, I bet you could have two
sensors, and start a timing loop when the car passes through the first gate.
Then have the program count loops until the second gate is triggered. The
only difficulty with this method is you have to have an oscilloscope to
measure the length of your loop in order to get an accurate readout in MPH.
If you are going to use infrared sensors, you may want to consider a
38-455kHz sensor instead of a regular type, as they have better range and
aren't as easily spoofed by ambient light.
Some of the other suggestions in this thread will work if you can have the
device in the car. If this is the case you have a number of options, like a
NIB magnet on the exsiting speedo cable. Let us know exactly what you need.
Jonathan
www.madlabs.info
Sent: Saturday, April 03, 2004 1:51 AM
> sensor!!
> > Daen,
> car or a
> need? The
> pretty
> > good accuarcy.
> one
> made as the
> is known,
> quite well
> > for my application.
> of more
> > help.
> > Jonathan
> > www.madlabs.info
> > > receive
> other
> > > pulse!
> use??
> Subject and
> > > Yahoo! Groups Links
> Yahoo! Groups Links
