DIRS — Parallax Forums
DIRS
edited 2004-04-13 06:13 in General Discussion
Hi group,
On the i2c communication experment, they said
Devtype con %1010 << 4 'device type
What does mean %1010 << 4?
and also...
Devaddr con %000 << 1 'address = %000 ->1
What does mean %000 << 1 and address = %000->1
As much as I read about DIR , I still have no clue!
Thank you all!
Rene
    edited 2004-04-03 20:17
    %1010 << 4 is the equivalent to %10100000 ... if you read up on the
    operators section of the manual, you'll find that << is the left shift
    operator. By the same token, %000 < 1 is equivalent to %0000.
    Why do it this way? I do it to torture newbies! Just kidding (I'm away
    from home and working on a Saturday so I can be silly...). The reason I
    do this in my programs (I wrote the example you're sighting) is that the
    device type of an I2C part is only 4 bits, but is positioned in the high
    nibble of a byte. The address of most (not all) I2C parts is three
    bits, and is also positioned.
    For that part, the write address turns out to be:
    %10100000
    Here's how the bits are organized (i = ID, a = Address):
    %10100000
    iiiiaaa
    Had I simply used the whole byte in the program I'm sure a bunch of
    folks would have asked how I got there. Now you know.
    -- Jon Williams
    -- Dallas Office
    From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9UfYNL3BcaXmz4MCdPZOf8PFxAunfTD9WWw2sKbm9zz6JrRyubktY9tPLLRoghg7Xh6d58oAKhUFQJt4CI44]rene.genest@q...[/url
    Sent: Friday, April 02, 2004 8:00 PM
    To: stamp
    Subject: [noparse][[/noparse]basicstamps] DIRS
    Hi group,
    and also...
    Thank you all!
    Rene
    edited 2004-04-04 09:04
    Thanks Jon,
    When I've read your answer, I laugh and realise suddenly that there
    are 2 fantastic things on that planet, 1st , we all have our own newbies who all
    count onto our knowledge to teach them as mentor on different branch as
    electronic, mechanic, skydive etc.., 2nd we also are the newbie of somebodyelse
    to get knowledge from them, and on Parallax, you and this group are my mentors!
    Regardeless the negative comments of thoses who try to reinvent the wheel, you
    still the best and cheapest "plug and go" solution on microcontroller market and
    I
    do not know how we could be better supported than that! As I tell to other, I've
    never ever asked a question whitout getting an explicit answer, and I really do
    appreciate everything I get from this group, it is diversified, relax and
    friendly.
    Thank you very much !
    Rene
    Jon Williams a
    edited 2004-04-12 04:39
    Hi group,
    In many program's initialisation we see " DIRS = %00000001110000000 "
    which said that pins 7, 8 and 9 are outputs and all others are inputs.
    But, while
    writing program code we also write for example " serout 7, n, [noparse][[/noparse]i, 195
    etc..."
    or " high 7" or "if in5 = 0 then......" such commands suppose to
    already
    define in or out to pins.
    So, how and why is it important to apply DIRS command and what would
    happen if we do not apply that command on certains conditions?
    Thank you!
    Rene
    edited 2004-04-12 21:53
    In many cases you DON'T have set DIRS bits, the BASIC Stamp will handle
    it for you. There are times when it is required, though.
    LED PIN 0
    Setup:
    DIR0 = 1
    Main:
    LED = 1
    PAUSE 100
    LED = 0
    PAUSE 100
    GOTO Main
    Since this program directly manipulates the OUTS register (OUT0 in this
    case) the DIRS bit must be set ahead of the main code. This version,
    however:
    LED PIN 0
    Main:
    HIGH LED
    PAUSE 100
    LOW LED
    PAUSE 100
    GOTO Main
    ... requires not manipulation of the DIRS bit because HIGH and LOW do
    that for us.
    To your question, there is no harm in setting DIRS bits ahead of
    instrucitons that will do that for us, the instruction will simply set
    DIRS as required for its use. Keep this in mind, and in some cases the
    DIRS bit will be left in a state other than where it started.
    -- Jon Williams
    -- Dallas Office
    From: Rene Genest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Pnk1GETF38ZvT31ngePKcQB1J9wuhBdYFjeAUfuDnpLkzNpyA1hK_nOxpQX6ylBtmtqT32Wj81QFOaZBvw]rene.genest@q...[/url
    Sent: Sunday, April 11, 2004 10:40 PM
    To: stamp
    Hi group,
    But, while writing program code we also write for example " serout 7, n,
    [noparse][[/noparse]i, 195 etc..." or " high 7" or "if in5 = 0 then......" such commands
    suppose to already define in or out to pins. So, how and why is it
    important to apply DIRS command and what would happen if we do not apply
    Thank you!
    Rene
    edited 2004-04-13 00:05
    Setting the 'DIRS' pin direction variable
    is needed so you can say:
    MyVar = IN1 ' This does NOT make the pin an input!
    for instance. If the P1 pin is still set
    as an output, you'll get the last value
    written to the pin, not the current value
    of the data on the pin.
    It is true that HIGH 1, and LOW 1, WILL
    change the pin to an output. But that is
    not true of all commands.
    --- In basicstamps@yahoogroups.com, Rene Genest <rene.genest@q...>
    wrote:
    > Hi group,
    00000001110000000 "
    inputs.
    > But, while
    195
    > etc..."
    > already
    > Thank you!
    > Rene
    Almost. OUT1 contains the last value written to P1. IN1 returns the
    logic level at P1, which--even if the pin is set to output--may in
    fact be opposite to what is in OUT1 if driven to the opposite state
    by external logic.
    Regarding the original question, I use DIRS most often as a quick
    and code-efficient way to set more than one pin to input/output mode
    rather than using individual INPUT or OUTPUT statements. Sometimes
    it's important to change multiple I/O states simultaneously.
    Because your Stamp's pins initialize to inputs you needn't always use
    the DIRS statement at the start of each program. It's a good way to
    force yourself to think through the role of each pin, however.
    Steve
    > wrote:
    > > Hi group,
    > 00000001110000000 "
    > inputs.
    > > But, while
    > 195
    > > etc..."
    > > already
    > > Thank you!
    > > Rene
