/////////Got Help??//////\/\/\/\/\/\/\_`-__-~_simple erro?
Hello
I fixed the rc time problem
and added returns instead of GOSUB
but my code is still very jerky.
I know its not the motor
because the "following code"
makes motor operate just as I need it to.
"following code"
DO
DEBUG "increnebt by 1", CR
FOR counter = 800 TO 500 STEP 1
PULSOUT 14, counter
PAUSE 100
DEBUG DEC5 counter, CRSRUP
NEXT
PAUSE 1000
LOOP
WHY? Does my code still move jerky??? ie large steps....
what simple thing Am I leaving out?? maybe??
:::::::::::::[noparse]:D[/noparse]ESCRIPTION:::::::
' this program moves a servo motor
' when RCTIME is = or greater than 03000
'{$STAMP BS2}
'{$PBASIC 2.5}
'I/O Definitions
PhotoA CON 0
PhotoB CON 1
ServoA CON 14
ServoB CON 15
'EEPROM MEMEORY
RightLeft DATA 800
UpDown DATA 800
StepOne DATA 800
'Variables
X VAR Word
P VAR Word
lightA VAR Word
lightB VAR Word
counter VAR Word
'Program Code
Main:
DO
GOSUB Photo_A:
LOOP
'Suburoutines
Photo_A:
DEBUG "Reading Light from Photo_A Now"
HIGH 0
PAUSE 1
RCTIME 0, 1, lightA
DEBUG HOME, "lightA = ", DEC5 lightA
READ RightLeft, x
IF (lightA > = 03000) THEN Servo_A:
RETURN
Servo_A:
FOR counter = x TO (x - 1) STEP 1
PULSOUT 14, counter
WRITE RightLeft, counter
NEXT
PAUSE 1000
RETURN
"following code"
DO
PULSOUT 14, counter
PAUSE 100
NEXT
PAUSE 1000
LOOP
'{$STAMP BS2}
'{$PBASIC 2.5}
'I/O Definitions
PhotoA CON 0
PhotoB CON 1
ServoA CON 14
ServoB CON 15
'EEPROM MEMEORY
RightLeft DATA 800
UpDown DATA 800
StepOne DATA 800
'Variables
X VAR Word
P VAR Word
lightA VAR Word
lightB VAR Word
counter VAR Word
'Program Code
Main:
DO
GOSUB Photo_A:
LOOP
'Suburoutines
Photo_A:
HIGH 0
PAUSE 1
RCTIME 0, 1, lightA
READ RightLeft, x
RETURN
Servo_A:
PULSOUT 14, counter
NEXT
PAUSE 1000
RETURN
crazyidagain@y... writes:
First of all, use English and have a proper subject matter.
You don't use RETURN instaed of GOSUB. Thjey work in conjunction. If
you have a GOSUB then you must have a RETURN. Read the manual on the GOSUB
command.
What do you mean by "jerky" code? Do you mean the motor is "jerky"?
> "following code"
> DO
> PULSOUT 14, counter
> PAUSE 100
> NEXT
> PAUSE 1000
> LOOP
> You don't need the Step 1. A for next loop will increment in steps of 1
> unless you specify otherwise.
If the above code is for driving your servo, you do not pause 100 between
pulses. You pause 20. Jon Williams mentioned this before.
The above code would move your servo from 800 to 500. When the for/next loop
has finished, it loops back to do it again and the servo snaps to 800. If
you want your servo to move slowly avaoid large rotational jumps.
This is an infinite loop. You haven't left yourself a way out - how does
your code get out of this do/loop?
Sid Weaver
W4EKQ
Port Richey, FL
is too large. You have a 100 millsecond PAUSE between servo refreshes,
but servos want to be updated every 20 milliseconds or so.
-- Jon Williams
-- Parallax
From: crazyidagain [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=D2z_vHHA4fuCHl5AJghOIILmNwgSPzuJKhPm7hLUxcmchZ0BhCvT7DV3GiMHpyxTd7kjttDfSarvWT3kRykG0g]crazyidagain@y...[/url
Sent: Friday, April 02, 2004 1:30 PM
Subject: [noparse][[/noparse]basicstamps] /////////Got
Hello
"following code"
DO
PULSOUT 14, counter
PAUSE 100
NEXT
PAUSE 1000
LOOP
'{$STAMP BS2}
'{$PBASIC 2.5}
'I/O Definitions
PhotoA CON 0
PhotoB CON 1
ServoA CON 14
ServoB CON 15
'EEPROM MEMEORY
RightLeft DATA 800
UpDown DATA 800
StepOne DATA 800
'Variables
X VAR Word
P VAR Word
lightA VAR Word
lightB VAR Word
counter VAR Word
'Program Code
Main:
DO
GOSUB Photo_A:
LOOP
'Suburoutines
Photo_A:
HIGH 0
PAUSE 1
RCTIME 0, 1, lightA
READ RightLeft, x
RETURN
Servo_A:
PULSOUT 14, counter
NEXT
PAUSE 1000
RETURN
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
