LCD Panel help
I am working with my students on the BPI-216 Serial LCD Module. I have
programmed and worked the first line very easily but the second line is
being difficult. I also wondered if the lines could scroll and how to
do that. Here is the one line program I am working with:
'{$stamp BS2}
N9600 Con $4054
I Con 254
Clr Con 1
Line2 Con 192
L1_C7 Con 135
Serout 7,N9600,[noparse][[/noparse]I,CLR]
Serout 7,N9600,[noparse][[/noparse]"Robots are fun"]
'{$stamp BS2}
N9600 Con $4054
I Con 254
Clr Con 1
Line2 Con 192
L1_C7 Con 135
wrote:
> Hi,
> I have programmed and worked the first line very easily but the
> second line is being difficult.
According to the documentation at
http://www.parallax.com/dl/docs/prod/audiovis/2x16seriallcd.pdf, you
would simply do
Serout 7,N9600,[noparse][[/noparse]I,LINE2]
Serout 7,N9600,[noparse][[/noparse]"Don't you think?"]
> I also wondered if the lines could scroll and how to do that.
According to the information at
http://www.melabs.com/products/bp216N.htm, you can scroll the display
one character at a time left or right (commands 24 and 28). I don't
know if this means that both lines move in unison or if when
scrolling left the leftmost character of the second line becomes the
rightmost character of the first line. If the latter is the case,
you could effectively scroll up and down by scrolling left and right
by 16 characters. You may want to turn the display off while this is
happening.
I have gone through both websites and tried your example but to no
avail. Can anyone lead me to a nuts and volts article or Wam experiment
with command help?
Thanks Mark
From: Don Kinzer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2xUiaAAHAJHgstyQ6w9tBlNLpvEUNZaWU4x0YGX9-lb4Yx7OJOE9tKuHQLdEG1ofZfbMz5fqiHqNJttV8g]dkinzer@e...[/url
Sent: Thursday, April 01, 2004 12:34 PM
Subject: [noparse][[/noparse]basicstamps] Re: LCD Panel help
--- In basicstamps@yahoogroups.com, "MARK DEVINE" <mdevine@s...>
wrote:
> Hi,
would simply do
happening.
Yahoo! Groups Links
>Thanks Don,
>with command help?
>Thanks Mark
Mark -
Do you have the SEETRON BPI-216 datasheet (BPI_BPK.PDF) ? If not, you'll find
it an invaluable resource for working with that unit. The PDF can be downloaded
here: http://www.seetron.com/slcds.htm .
Note carefully the comments about positioning the cursor, and that all
alpha-numeric LCD modules having 80 bytes of internal memory (Page 4 of the
PDF). Also look carefully at the definition of LINE2 in the Stamp II
demonstration program provided. This establishes the cursor positions for the
second line of text.
Line 1 character 0 = 128 and Line 2 character 0 = 192 ... Aha he said :-)
Scrolling requires the use of codes 24 and/or 28, as noted in the datasheet.
Once those concepts are implemented the rest should be easy going.
Bruce Bates
From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=q2J5S0P5sqsXxZ2SkjhRdpDEW3Pdr8qV_EWfAgCjCO7aCl28xBJJ3jwhnz6g9Qcdz79N1D99r2OtWJnj]mdevine@s...[/url
Sent: Wednesday, March 31, 2004 11:06 PM
Subject: [noparse][[/noparse]basicstamps] LCD Panel help
'{$stamp BS2}
N9600 Con $4054
I Con 254
Clr Con 1
Line2 Con 192
L1_C7 Con 135
Yahoo! Groups Links
the BPI-216 when using 9600 baud. This is the nature of LCDs.
-- Jon Williams
-- Dallas Office
From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SDk_MmwGZzwTGHu-bkP7Gg3A2yt-p5PRW-e9yMNssnrCgDSAfa4WYPnEzt38Q-BdPeWAz-RAEWWK]mdevine@s...[/url
Sent: Wednesday, March 31, 2004 10:06 PM
do that. Here is the one line program I am working with: '{$stamp BS2}
N9600 Con $4054
I Con 254
Clr Con 1
Line2 Con 192
L1_C7 Con 135
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
said, Scott originated the "Stamp Applications" column so there are
several articles that use his LCDs (some I wrote too). You'll just have
to work your way through the PDFs on our web site.
-- Jon Williams
-- Dallas Office
From: MARK DEVINE [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EFjb6Xc6Xjdy9LYhwIM282lv7OHwCvU9cZOZJr7SJs32_G31MM6WsvkB6-g0s-UNcZS7gOZEHeIgAttJ4Q]mdevine@s...[/url
Sent: Thursday, April 01, 2004 2:30 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: LCD Panel help
Thanks Don,
with command help? Thanks Mark
From: Don Kinzer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dEhzx1cf9x8x_pszyRXnrh5otyyzMhyGkAkYQFJu20M5UTplEmjmKLtYRFBh5doR61IgeYaukxXBfpIFlDAUuw]dkinzer@e...[/url
wrote:
> Hi,
> is being difficult.
would simply do
happening.
Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
