P-Channel MOSFET
Do any of you know of a P-Channel compliment or equivalent to the N-Channel
IRL520 MOSFET? This is for a Basic Stamp related project by the way. I'd
like to be able to use logic control on either the negative or positive
side of a load as I need to.
Tim
Tim
up, or is it completely trial and error? I can't be the only one who could
use advise from the pro's here.
Tim
>Thanks,
>Tim
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Yahoo! Groups Links
Otherwise, you will have to look at the characteristics and figure it out
yourself<G>.
From: Timothy Medema [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vRJr7CQofoCObNyJzu0QK4HJh8va3PUD_lm_-4txe-Xgq-1GjTKQwPrT6dfu4UlBicoQuARgd0jEJWnv]timm@c...[/url
Sent: Wednesday, March 31, 2004 4:52 PM
Subject: Re: [noparse][[/noparse]basicstamps] P-Channel MOSFET
Better yet, what method can you recommend for looking something like this
Tim
>N-Channel IRL520 MOSFET? This is for a Basic Stamp related project by
>the way. I'd like to be able to use logic control on either the
>negative or positive side of a load as I need to.
>Thanks,
>Tim
>and
>Yahoo! Groups Links
Yahoo! Groups Links
> [noparse][[/noparse]W]hat method can you recommend for looking something like this
Generally, if you search for the device number and the
word "complementary" (note the spelling), you'll find references to a
complementary part. You can also look for a device with similar
parameters. This is more difficult unless you have data in a
convenient form.
I found nothing for this part. It may be because this device is a
logic MOSFET, intended to be gated by a 5V logic signal. (Perhaps
the L in the device number indicates Logic). I haven't thought it
through completely but it may impossible to construct a p-channel
logic MOSFET. All of the IRLxxx parts that I've seen are n-channel.
current you are going to pull through the device
http://www.fairchildsemi.com/ds/FD/FDG316P.pdf
http://www.fairchildsemi.com/ds/FD/FDN336P.pdf
ken
Tim
Logic level P-Ch MOSFETs aren't quite as useful as the N-ch variety if your
load voltage is greater than 5 volts, as is often the case...
First, let's consider the common N-Ch setup with a device like the IRL520N.
The MOSFET is switching on the ground side of the load, with the "source"
connected to ground, the "drain" connected to the load, and the "gate"
connected to the Stamp I/O pin. The positive supply voltage is connected to
the other side of the load. The MOSFET is off when the gate voltage is at
the same level as the source. That would be when the Stamp pin is driven
low in this case. When the Stamp pin is driven high, the gate is now 5
volts more positive than the source, and the MOSFET is turned on. Note that
it doesn't matter if the load's power supply voltage is 5V, 12V, 30V,
tc. -- the gate will still be either at 0 volts or +5 volts relative to the
source, which is good.
Now let's take a look at a typical P-Ch connection, which would be the
equivalent of using a PNP transistor to switch on the positive side of the
load. The MOSFET will be connected between the B+ supply and the "top" side
of the load, with the other side of the load connected to ground. Let's say
we're using a +12V supply for the load...
Think of this as a mirror image of the N-Ch arrangement. The P-Ch MOSFET's
source is connected to +12V, and its gate must be at the same voltage level
as the source to turn it off, or must be brought more negative (toward
ground) to turn it on. So the gate must be at +12 volts to keep the MOSFET
off. If you connect the gate directly to the Stamp I/O pin, the gate
voltage will be at +5 volts with the Stamp pin high, and at 0 volts with the
Stamp pin low. Either way, the MOSFET will remain on since the gate will be
7 volts more negative than the source when the Stamp pin is high, or 12
volts more negative than the source when the Stamp pin is low. Remember
this is an "upside down" mirror image of the N-Ch arrangement.
An easy way to deal with this dilemma is to use a NPN transistor such as a
2N3904 connected to the Stamp I/O pin as a level translator. The emitter
would be grounded, the base connected to the I/O pin through a ~10k series
resistor, and the collector would be connected to the P-ch MOSFET gate. A
pull-up resistor (10k is fine) would also need to be connected between the
MOSFET's gate and source. The resistor values could be increased or
decreased depending on how "hard/fast" you needed to switch the MOSFET. For
slow switching, it isn't critical. If you're doing high frequency PWM, it's
a very different story.
With the Stamp I/O pin low, the NPN is off, so the pull-up resistor pulls
the MOSFET gate up to B+, turning it off. When the Stamp I/O pin is driven
high, current flows through the NPN base, turning it on. That pulls the
MOSFET gate to ground, turning it on. In this configuration, there is no
advantage to using a logic level P-Ch MOSFET. If you're using a +5V supply
to the load, then the logic level P-Ch would be fine with the gate connected
directly to the Stamp pin. But it's only a matter of a few pennies for the
2N3904 (or any small NPN) and the two resistors.
...So that's why I stock the P-Ch IRF9530N, which is not logic level, but is
a good complement to the IRL520 and IRL530. (100V max, with similar on
resistance and current ratings.) [noparse]:o[/noparse])
-Randy
www.glitchbuster.com
Sent: Wednesday, March 31, 2004 1:02 PM
Subject: [noparse][[/noparse]basicstamps] P-Channel MOSFET
N-Channel
> Thanks,
> Tim
> Yahoo! Groups Links
wrote:
> Hi Tim,
if your
IRL520N.
the "source"
the "gate"
connected to
voltage is at
driven
now 5
Note that
30V,
relative to the
the
of the
the "top" side
Let's say
MOSFET's
voltage level
(toward
the MOSFET
gate
with the
gate will be
or 12
Remember
such as a
emitter
series
gate. A
between the
MOSFET. For
PWM, it's
pulls
is driven
pulls the
is no
+5V supply
connected
for the
level, but is
similar on
> -Randy
Interesting take and good application.
Logic Level MOSFETS are probably much easier to use than trying to
use mosfet drivers.
Also, it is possible to bootstrap the signal to an NPN device to use
them in place of a PNP. That makes it simiplier to have one unit for
both but it does complicate the circuit.
Dave
Thank You! I now understand MOSFET's better than I have before. You have
explained complete examples here and that learning method works so well for
me. Also, I'll be able to refer back to your examples if my memory fails
me, should a little time pass until the next time. I really appreciate
your time invested and I'm surely not the only one to benefit from it
within our group.
Tim
At 12:30 AM 4/1/2004, you wrote:
>Hi Tim,
>-Randy
>From: "Timothy Medema" <timm@c...>
>N-Channel
> > Thanks,
> > Tim
> > Yahoo! Groups Links
>Yahoo! Groups Links
It is clear to me that I have to make more time to study! I enjoy
electronics very much, but I'm one of those people that the subject doesn't
come very easily to.
Tim
At 05:00 AM 4/1/2004, you wrote:
>--- In basicstamps@yahoogroups.com, "Randy Jones" <randyjones@w...>
>wrote:
> > Hi Tim,
>if your
>IRL520N.
>the "source"
>the "gate"
>connected to
>voltage is at
>driven
>now 5
>Note that
>30V,
>relative to the
>the
>of the
>the "top" side
>Let's say
>MOSFET's
>voltage level
>(toward
>the MOSFET
>gate
>with the
>gate will be
>or 12
>Remember
>such as a
>emitter
>series
>gate. A
>between the
>MOSFET. For
>PWM, it's
>pulls
>is driven
>pulls the
>is no
>+5V supply
>connected
>for the
>level, but is
>similar on
> > -Randy
>use mosfet drivers.
>Dave
>Yahoo! Groups Links
Thank you for your help with the search criteria. I often find this to be
a time consuming and frustrating part of a project. I had done a similar
search and found nothing as well.... I hoped that I had missed something or
that someone had a neat technique to hear about.
Tim
>convenient form.
>Yahoo! Groups Links
Hi Randy,
within our group.
Tim
