BS2PE and GPS Question
I'm working on a project where I am sending a standard $GPRMC data
string from a Garmin GPS 15L to a BS2PE. I am getting data, but it
seems to be just junk data. Here is my test code, just to see if I'm
getting a readable string:
GPS BYTE BYTE(20)
LOOP:
SERIN 10,16884,[noparse][[/noparse]STR GPS/20]
DEBUG STR GPS
GOTO LOOP
I'm thinking its a timing issue but I can't figure out what I need to
change, I can hook the GPS up to my PC serial port and read the data
perfectly through Hyperterminal. The GPS is set to output at 4800
baud. If anyone has any suggestions they would be much appreciated.
Thank You
Sean Vreeland
GPS BYTE BYTE(20)
LOOP:
DEBUG STR GPS
GOTO LOOP
Thank You
Sean Vreeland
If memory serves, the '2pe is clocked at the same effective rate as
the BS2 and uses the same SERIN/SEROUT baud arguments. Try:
SERIN 10,16572,[noparse][[/noparse]STR GPS\20]
Steve
> seems to be just junk data...
correct value would be 16572.
You can make your life a little easier with serial devices by adding
this to your standard programming template.
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
T38K4 CON 45
#ENDSELECT
Inverted CON $4000
Baud CON T4800 | Inverted
Using conditional compilition, the editor will correctly set the baud
rate parameter for the BASIC Stamp you're connected to.
-- Jon Williams
-- Dallas Office
From: seanvreeland [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OwyESC0PcoG_sNtCZ2k4THwoaQWuSsjErFXOPYuwYezns15502UTJkgZ_uw5xE1n3jc_XdsnZkktAW-AcK0]svreeland@m...[/url
Sent: Wednesday, March 31, 2004 1:56 PM
Subject: [noparse][[/noparse]basicstamps] BS2PE and GPS Question
GPS BYTE BYTE(20)
LOOP:
DEBUG STR GPS
GOTO LOOP
Thank You
Sean Vreeland
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
