SV: [basicstamps] Cable Question
Greetings!
The cable is a normal 'straight-through' cable, so the one with a DB25 can be
used if you have the correct connectors on the PC and BS carrier boards.
Trygve
Opprinnelig melding
Fra: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cfjFrNkSzSuKOghaKnEDcYv1goQaZIF19TwZuZmmtGFXmuorIjDxGgmjNAJEzfaiDwi2t50a-gB-nQFmR4MEHQ8gLk1v]hansolofalcon@w...[/url
Sendt: 31. mars 2004 10:54
Til: basicstamps@yahoogroups.com
Emne: [noparse][[/noparse]basicstamps] Cable Question
Hello from Gregg C Levine
A 3:50AM ET, (US) question for all of you.
What sort of "serial cable", is the norm for the BS-2, and the BS-1. with the
adapter? I'm guessing that I can't use the MODEM cable that has a DB9 connector
at one end, and a DB25 connector at the other. Ordinarily I'd fabricate my own,
but since they do exist, I'd like to find out what to ask for, if that's what is
necessary.
And yes, I've got a project looming that's a real hummer, for mine.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
from the same email address that you subscribed. Text in the Subject and Body
Yahoo! Groups Links
Trygve
Opprinnelig melding
necessary.
Yahoo! Groups Links
