pager motor
Does anybody have any knowledge or links about building a pager motor
controller.
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
controller.
Do you Yahoo!?
with is a small DC motor that has an offset weight on its shaft to cause
it to vibrate.
-- Jon Williams
-- Dallas Office
From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Wc0TaE2andJkC6pqBTSsuRjB4_BlVXDLY_bW5VgtEZtZA6JpnFwBL8dK-aklv7l6SmMQiHpvNoRqq5ekB4Nb]crazykurby@y...[/url
Sent: Tuesday, March 30, 2004 4:17 PM
Subject: [noparse][[/noparse]basicstamps] pager motor
controller.
I just aquired about 20 old pagers and made a dc motor
controller using the L293D Chip. It's easy and can
control 2 motors both foward and reverse.
Hope this helps.
Curtis
> building a pager motor controller.
> Do you Yahoo!?
> time.
> removed]
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
http://taxes.yahoo.com/filing.html
Jon Williams <jwilliams@p...> wrote:How about a standard transistor
switching circuit? All you're dealing
it to vibrate.
-- Jon Williams
-- Dallas Office
From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fiLRT_w4ECGFlpyge029FZLYkQk-wkqdvIrpUHWiWbzlA5z92uiAqKZMePWIIc4qJjYEgoe3MX7uZmr3]crazykurby@y...[/url
controller.
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Yahoo! Groups Links
Do you Yahoo!?
an off-balance weight, it is nothing more than a dc motor. Put voltage on
it and it will rotate, reverse the connections and it will rotate in the
other direction. For circuitry to control the direction and speed, check
out this web site for examples. http://www.geocities.com/jimforkin2003/
Incidentally, if you want to remove the weight, crush the weight with pliers
across the widest part and, in most cases, it will slip off the shaft
without any damage.
Jim
From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4BSTc28ZGU0MV9YQE4Eqksly-o49PljnDmT8zQb_7TEveemNAma0URpj9_6vZhPNNDAYTDbMxyfAIg]crazykurby@y...[/url
Sent: Tuesday, March 30, 2004 5:17 PM
controller.
Do you Yahoo!?
Yahoo! Groups Links
voltage overhead a standard transistor switching circuit is fine,
otherwise I would consider using a mosfet. For controlling the
speed a simple transistor current mirror works well.
>How about a standard transistor switching circuit? All you're dealing
>it to vibrate.
>-- Jon Williams
>-- Dallas Office
>controller.
Beau Schwabe Mask Designer National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Home: polygon_man@h... Mail Stop GA1
Work: bschwabe@a... Norcross, GA 30071
anything about voltage or amperage. I guess the voltage is close to the pager
motors. I only need to control vibration strength. Thanks everyone for the help.
Jim Forkin <jjf@p...> wrote:If you mean the little motor used to vibrate
a pager/cell phone by rotating
without any damage.
Jim
From: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z7RcSrmM7eaYxH0bxEC2NdkEwZ7TeA44-eT3uJQTtFgQ7YCJcgPenV3W1-QjrzHPReSpbpn0lyfRaukyRw]crazykurby@y...[/url
controller.
Do you Yahoo!?
Yahoo! Groups Links
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway - Enter today
