solutions cubed fault
Hello,
I am a new stamp user and this is the first aplication I have set
up. I am trying to run a solutions cubed motor mind c with a bs2 in
serial mode and am having some real problems. I have used a
downloaded program template and changed it to my application.
Nothing about the program has changed with regard to the set up of
the pwm registers but when I go to change the values the motors
don't act as they should. Any negative number should reverse the
motor and an positive motor should run the motor forward (up to
1023) what am I doing wrong. Also, in the process of trouble
shooting the system I have a fault on the motor mind C and can't
clear it. I have the manuals but can't get the command to execute a
clear fault, I think. Any help or advise would be greatly
appreciated.
Dan
appreciated.
Dan
>Hello,
>appreciated.
>Thanks,
>Dan
Dan -
Solutions Cubed has their own support forum where you might get your answers
much more quickly, and from the folks who developed the products. They can be
accessed here: http://www.solutions-cubed.com/Solutions%20Cubed/ .
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and Body
>Yahoo! Groups Links
