Stumped
I just got started in microcontrollers. I have a Rev B BASIC stamp
HomeWork Board, and i'm using the Stamp Editor ver 2.0 Beta 2. I
have a AAS in electronics, so I am comfortable with the projects in
my Stamp In Class booklet. The odd thing, when I run a DEBUG
statement, the stamp performes fine. But when I try the below
program on the stamp, the power light flashes once, at the same time
the led on P15 coupled through a 470 ohm resister to Vss, flashes
only once. Nothing else happens. But when I add a DEBUG "1"
statement before the LOOP command, the stamp flashes the LED and the
screen shows a one repeatedly. Why would I need to add a DEBUG
statement to make a loop function work? I'm comfused. Please help.
DO
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
LOOP
DO
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
LOOP
port shutting down ... we've seen this a thousand times (cheap serial
ports are the bane of our existence). Two things you can do to mitigate
the problem.
1) Set your port FIFO settings to their minimum values
2) Add a DEBUG statement to your program (this holds the port open so
the computer doesn't want to shut it down).
Main:
DEBUG "LED Flasher"
DO
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
LOOP
-- Jon Williams
-- Dallas Office
From: carns256 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nIRXrYDnshZJAX0W3SGxW__z-lhnyQWZcbqFTmTMXKxXt9EVpnvlRmtC11kQmzgRaRphF6-3ae2wufdj]carns256@y...[/url
Sent: Monday, March 29, 2004 8:04 AM
Subject: [noparse][[/noparse]basicstamps] Stumped
DO
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
LOOP
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You're running a laptop, aren't you? This has to do with your
serial
serial
mitigate
> the problem.
so
> Main:
> DEBUG "LED Flasher"
> DO
> HIGH 15
> PAUSE 500
> LOW 15
> PAUSE 500
> LOOP
> -- Jon Williams
> -- Dallas Office
> From: carns256 [noparse][[/noparse]mailto:carns256@y...]
time
the
> DO
> HIGH 15
> PAUSE 500
> LOW 15
> PAUSE 500
> LOOP
of the Parallax editor (2.1 Beta 1) this will work
as expected;
'{$STAMP BS2}
'{$PBASIC 2.5}
DO
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
LOOP
This will not;
'{$STAMP BS2}
DO
HIGH 15
PAUSE 500
LOW 15
PAUSE 500
LOOP
You need to insert the '{$PBASIC 2.5} for this type
of DO loop structure to work as expected.
--- In basicstamps@yahoogroups.com, "carns256" <carns256@y...> wrote:
> Yes I am running a laptop. Thanks for the information.
> serial
> serial
> mitigate
> > the problem.
open
> so
> > Main:
> > DEBUG "LED Flasher"
> > DO
> > HIGH 15
> > PAUSE 500
> > LOW 15
> > PAUSE 500
> > LOOP
> > -- Jon Williams
> > -- Dallas Office
stamp
in
> time
> the
help.
> > DO
> > HIGH 15
> > PAUSE 500
> > LOW 15
> > PAUSE 500
> > LOOP
